JC Whitney's 4bbl intake
Old May 19, 2002 | 05:22 PM
cw50must's Avatar
cw50must
Old May 26, 2002 | 10:44 AM
countryboy29's Avatar
countryboy29
JC Whitney sells an intake manifold that bolts on, and allows you to add a 4bbl carb. To your inline six. Have any of you ever, used this or know someone who has?
Old May 26, 2002 | 02:14 PM
whittey's Avatar
whittey
JC Whitney sells an offenhauser intake. I don't know if they sell both the single and dual plane, but thousands of people have that intake. They are relatively common (as far as performance 300 parts go)...
-=Whittey=-
Old May 26, 2002 | 07:06 PM
gray79f250's Avatar
gray79f250
I have an offy intake on my f150 and it rocks. Very good choice
Old May 26, 2002 | 08:54 PM
countryboy29
Thanks Guys
Old May 26, 2002 | 10:05 PM
Vampiro's Avatar
Vampiro
how much is this intake? i seem to have lent my JC whitney catalog away and never got it back. i would die for a 4 barrel carb
Old May 26, 2002 | 10:23 PM
gray79f250's Avatar
gray79f250
Vampiro jegs.com has them for 199.99 heres a link to the page. Keep in mind if your gonna put this on go with a header aswell. I use a 600 edelbrock carb on it but have a different cam aswell.
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2347&prmenbr=361
Old May 27, 2002 | 03:33 AM
kameleon's Avatar
kameleon
>..... Keep in mind if your gonna put this on go with a
I have the intake mentioned..... I ordered it from jc wjitney only cause jegs was on back order with it when I ordered. I also have the edelbrock 600cfm carb and dynomax headers and the crane cams performax dual pattern cam. The only advice I can give is use half washers on the exhaust side of the manifold to compensate for the thickness difference...... I learned the hard way..... plus make sure you get the "C-series" offy intake..... not the DP.
Old May 27, 2002 | 01:53 PM
bigsixguy's Avatar
bigsixguy
Post JC Whitney's 4bbl intake
Okay, I ordered the 390 Holley and the Offy Dual Port intake from Jeg's this morning, I have a Crane 260-H Powermax cam and springs, and the block and head are at the machinists' as we speak.
Now for my question, Why not the DP Offy? The Open Plenum model at JCW is for a much wider/higher rev range than I want, and the specs don't tell me that it will help way down low on the tach.
I am pulling a 18.5 foot travel trailer and the truck has the 3 speed w/overdrive (RUG/RTS? I dunno). As it is now, the rear end is geared way too high and I get a bit of chatter out of the clutch on takeoff, so I'll lower that a bit, and the engine mods should help out a great deal.
Thanx in advance for the reply, hope I didn't waste my money!
Cheers!
Les
Old May 28, 2002 | 07:28 PM
gray79f250's Avatar
gray79f250
I think you did well on the intake adual plane versus an open plane will produce more low end hp and torque on any engine. You shoulld look into a header for sure I have a pacesetter brand which is a dual outlet also. If you do change the cam you should avoid high duration for towing. The thing i do question is the 390cfm as I have used both a holley and an edelbrock 600cfm on my 300 and both worked great with only very minor tuning. But im thinking if you keep the stock cam a 390 might not be bad.
Good Luck Andy
Old May 31, 2002 | 10:31 PM
BigJake86's Avatar
BigJake86
What kind of power are these 300's putting out with the 4 barrel carb, cam, etc.?
Old Jun 1, 2002 | 01:01 AM
kameleon's Avatar
kameleon
I am not sure exactly how much mine is putting out but I do plan to have it dyno'd at the local Wynne Speed before I do any other mods. I will post the results when I get them.
