ram air
Old Apr 28, 2002 | 05:40 PM
TJ82f150's Avatar
TJ82f150
ram air
anyone know where i can get a ram air set up for my truck i heard that this make a huge improvement
or if i cant find one could someone tell me where theres some pictures of the set up or some diagrams cause ill make one if the actually unit is to expencive thanks guys
82 F150 shortbed 4x4 6in lift 35'BFG's 300six EFI headers ramair(hopefully) 2 1/2 exhaust straight back no cat
Old Apr 28, 2002 | 06:59 PM
MustangGT221's Avatar
MustangGT221
ram air
I have one but they are only made for 92-96 trucks.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Apr 28, 2002 | 08:14 PM
Vampiro's Avatar
Vampiro
ram air
you can make your own ram air setup. it's really easy. just get another snorket, some door rivets. rivet the snorkel to the beather after cutting the hole out. and some ducts to under the bumper or where ever and that's it
Old Apr 29, 2002 | 09:14 PM
DrkPhanstm's Avatar
DrkPhanstm
ram air
Mustang: How about a pic of the ram-air setup? I looked on your gallery.. but it didnt have anyhting of the engine.
I was planning on making my own this summer. I planned on removing the factory snorkle thing that comes off the box and replacing it with 2-3in hoses that go through the radiator support( where the snorkle was.. but enlarge the hole a tad) and then make a collector that would replace that rubber "flap" behind the grill. The collector would be behind the grill but 3-4in past the edge of the grill opening ( if that makes sense to anyone) its basically an improved factory setup, in my mind at least
Old Apr 29, 2002 | 09:33 PM
Vampiro's Avatar
Vampiro
ram air
[updated:LAST EDITED ON 29-Apr-02 AT 10:34 PM (EST)]that'll work easily bud! id do it! but then i also bought a open air breather, that works very nice too, except not in cold weather, like below 0
Old Apr 30, 2002 | 06:33 PM
BlueMeanie's Avatar
BlueMeanie
ram air
In the Summit catalog in the Mustang section (I think) towards the back is a picture of a ram air set up.
It might look a little wierd to have a snorkel end hanging from the bottom of the bumper, just my 2 cents.
I like the idea of bringing air in from the grill. There's a lot of posibilities. Toyota Supra's (80's) have something like that, where the air comes from the grill, through the filter which is totally enclosed, and into the intake. I thought about trying that with a K&N cone filter and some sort of duct work.
Also, the washer fluid/radiator tank seems like it could be moved around under the engine - like turn it around to where the factory air filter box sits. That places it kind of close to the fuses, though. But that would open up a lot of room for an intake/duct/whatever.
Old May 25, 2002 | 05:09 PM
davewild's Avatar
davewild
ram air
Old May 31, 2002 | 12:55 PM
tranthac1's Avatar
tranthac1
ram air
When you finish your project, send me a photo.
thanks.
Old May 31, 2002 | 01:22 PM
82F100SWB's Avatar
82F100SWB
ram air
I started this on my 82 a while back: http://www.stfx.ca/people/edmacdon/fordpage/hood.jpg
I'm eventually gonna finish it... The 'ol Merc Cyclone's ran a similar setup, but, I haven't been able to come up with a good way of hooking the holes in the hood into the intake that I could do for cheap(budget was very tight while I was working on that) and, I changed the hood when I put the body back on, and, haven't really done anything with it.
Evan MacDonald
1982 F100 SWB
300 HD: Cliffy 290H, 9.1:1 compression, forged everything, ARP'd bottom end/Hedman hedder/dual 2½" exhaust
NP 435/2.75 geared 9"
1985 F150 HD, 300 HD/needs a NP 435/4.10 geared 8.8
70,000 miles
1980 F100 Custom, 300/Np 435/2.75, 58,000 miles
Old May 31, 2002 | 11:08 PM
FE427TP's Avatar
FE427TP
ram air
www.ramairbox.com
Old Jun 1, 2002 | 08:40 AM
Silver Streak's Avatar
Silver Streak
ram air
You might try adapting an inlet tube from an 88-91 model or a 92-96 deisel. My 1990 came stock with ram air, all I had to do was remove the baffle in the front of the tube. For some reason, in 92 they started running this tube over the top of the radiator where the air can get nice and hot. The earlier tube sticks through the core support and hides right behind the grill.
Old Jun 1, 2002 | 04:30 PM
StrangeRanger's Avatar
StrangeRanger
ram air
MustangGT221,
Where did you get your ram-air? I've been looking for one for my 96.
Old Jun 1, 2002 | 04:51 PM
chuckman's Avatar
chuckman
ram air
Cervin's makes the ram-air hood and kit for the 92-96. You can find them at cervinis.com, or you might be able to find them at miscellaneous mustang shops.
Old Jun 1, 2002 | 09:41 PM
MustangGT221
ram air
Yup, i got mine from cervini's, sorry i havnt been around much since i don't have an inline six anymore after my truck got totalled. The two scoops on the front of the hood, underneath, have separate ducts that flow over to the airbox (on the underside of the hood). Once it gets to above the airbox, both ducts form a square that when the hood is closed, connects ontop of the airbox. They give you a special thing to flip the airbox and a lid to connect it up. There is a drain built into the ducts..where they form a square, that drains the water out, i've sprayed water from a hose down there and it didnt get anything wet. Good product info at cervinis.com.
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some kablamo Firestoner Wilderness ATs .
Pictures coming soon.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
82_F100_300Six
Ford vs The Competition
Aug 4, 2016 11:19 AM
SSgt82-02
2015 - 2020 F150
15
Feb 27, 2016 12:36 PM
zimm
6.7L Power Stroke Diesel
61
Jan 20, 2016 06:55 AM
MikePacey
30
Sep 5, 2011 04:52 PM
jmcrawf1
2004 - 2008 F150
May 9, 2008 07:43 AM
