speedo problem Fixed (maybe)
Old Nov 12, 2007 | 04:45 PM
97 HD's Avatar
97 HD
Im shure some of yall rember ive had speedo issues. Well Saturday i took the insturment cluster out and done some diging. I went in looking for loose wires or burnt connections and also cause i wanted to know what a PSOM looked like. I ended up dissassembeling the entire instrument clucster, removed all of the guages and checked everything. I found no burnt connections on the PSOM or no obviously loose connections. I put everything back together and the speedo has worked fine since. There must have been something loose or some minor corrosion on the connections where the guages plug into the cluster. Im keeping my fingers crossed that it is fixed. I did learn that against what ive been told the PSOM can be replaced by itself if you could find one. I was told that the only way to replace to PSOM was to replace the entire cluster.
Old Nov 12, 2007 | 05:11 PM
c00nhunterjoe's Avatar
c00nhunterjoe
keep up posted, anything is possible. maybee she just felt deglected and wanted some attentiuon....lol
