bent tappets
Old Nov 12, 2007 | 03:01 PM
drof46's Avatar
drof46
bent tappets
I have a 65 352/390 (still unsure). Anyway I have been playing hell to get it running. Then out of desperation today I pulled the covers off to make sure I wasn't way off on the timing(and to getter a closer look inside). Well #3 intake tappet and #5 exhaust tappet are bent all to hell. So my question is how far do I need to tear down this engine to replace these tappets? Can I just put in a couple new tappets and give it another try or do I need to pull her out of the truck and tear it apart?
Thanks
After a few rotations the other tappets/valves seam to be straight and doing what they are suppose to.
Old Nov 12, 2007 | 03:25 PM
ford390fe's Avatar
ford390fe
When you say tappets I'm assuming you mean the rockerarms? If that is the case you can remove the whole shaft assembly with it in the vehicle and get a new shaft assembly. To remove it start to losoen the middle bolts and work outward gradually. When you put a new one in, start in the middle and gradually tighten them to prevent any bending or breaking the shaft then torque them to specification. You don't have to adjust them unless they are the adjustable type which I don't think they are. Make sure to put a little assembly lube on the rocker tips and pushrod ends. My only question would be how would this bending have occured? If somebody has any idea please put in your two cents.
Aaron
Old Nov 12, 2007 | 03:27 PM
bertha66's Avatar
bertha66
"Tappets" are we talking push rods? If we are you can replace, but did they bend because to valves were stuck? or the lifters stuck? Take a rubber hammer and pop the valve springs and see if the move. You can put differant push rods from a differant cylinder in place of the bent ones and rotat the engine by hand to watch what they do, what do ya have to lose if you bend them?
Old Nov 12, 2007 | 03:47 PM
drof46's Avatar
drof46
thanks, I meant push rods. Autozone has some standard size for 99cents each so I'll take a spare and see if they are the right size. I will also try hitting those valves and see if they are stuck. Engine has sat a while so its a likly possibility.
thanks
Old Nov 12, 2007 | 03:53 PM
drof46's Avatar
drof46
Yippee looks like a valve job is in the future of these heads. Valve was stuck and even when driven down it stayed down. Wonderful. I have a 390 in the shop so I will just see which heads are in the best shape and start the rebuild process I guess.
Thanks
Old Nov 12, 2007 | 04:13 PM
Redmanbob's Avatar
Redmanbob
Dohhh speak of the devil LOL
Old Nov 12, 2007 | 10:30 PM
drof46's Avatar
drof46
I know we have number dummy, maybe with all my stupid luck and questions I could change my name to just dummy, lol.
later
Old Nov 12, 2007 | 10:38 PM
Redmanbob's Avatar
Redmanbob
As in the PM, this is the place to get your ducks in a row for either self build or shopped out. Don't get suckered by some 1/2 **** shop who builds chevy ****...go in and probe them for details..if they cant close it without a dumb look... You might wanna look around.. No "you do want to look around" if DIY, all the help you'll need is right here.. ask away.. these folks are kick ***!
Old Nov 13, 2007 | 08:04 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Just Remember !!! there's NO such things as a Dumb Question ! If you dont know? How are you supposed to learn?
Like Bob said, ask away......
RJ
Old Nov 13, 2007 | 08:24 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The only "dumb question" is the question that is never asked.
You've got an FE and you have questions.
You're in the right place
Old Nov 13, 2007 | 11:59 AM
dffay's Avatar
dffay
https://www.ford-trucks.com/article/...le_Secret.html
Here's a good article for the re-start after the valve job.
4bars13stars
34
Aug 28, 2016 07:56 PM
f-150_1993
63
Dec 23, 2013 01:27 PM
Aussie-crow
Dec 2, 2012 07:14 PM
just another truck
51
Oct 29, 2012 10:53 AM
jerg_064
Aug 15, 2008 09:26 AM
