New Head
Old Jun 6, 2002 | 11:35 PM
a_Pink_Bunny's Avatar
a_Pink_Bunny
New Head
Old Jun 9, 2002 | 07:12 PM
a_Pink_Bunny
New Head
anyone know what the ford part # is for teh Head on an '81 300?
I have recieved a head from a relative with part #E7TZ-6049-M and I wondering if it would work on my ford? Any help would be appreciated.
Old Jun 9, 2002 | 08:01 PM
DrFord's Avatar
DrFord
New Head
that head come off of a fuel injection motor. I don't know if this will affect you or not since the injectors sit inside the intake. my only concern would be that the intake/exhaust manifold bolt patterns would differ.
someone more knowledgable than myself should be able to help you out more
the head itself was first made in 1987. so it ould be somewhere in that timeframe.
Old Jun 9, 2002 | 08:18 PM
mantta's Avatar
mantta
New Head
The intake and exhaust bolt pattern is the same. There may be a little different combustion chamber volume. That could be be a benefit if it is a little less. Another thing is the holes where the smog pump discharges into, if it has them they cn be plugged if you don't use them. Other than that, it should fit fine.
Old Jun 9, 2002 | 11:21 PM
Ziggy___'s Avatar
Ziggy___
New Head
I don't know much about the other bolt ons, but I do know that the combustion chamber is smaller. The 86 has 8.5 compression with flat topped pistons, and the 87 has 8.8 with dished pistons to lower the compression. EFI heads with older pistons might have a high enough compression to require premium gas to prevent knocking. I got my info from a Ford service publication that they send out at the beginning of each model year to tell mechanics about any changes. Unfortunately, it doesn't give me the combustion chamber volume.
Ziggy
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
