Door Swap
Old Feb 1, 2021 | 06:51 PM
  #46
Venomouskev's Avatar
Venomouskev
Ok so
Originally Posted by GrimOne
Is there some sort of adjustment on the door itself? The door on my 96 was replaced before I bought it. But it looks like it doesn't fit quite right, not to mention that when closed sitting inside the truck I can look back and see daylight through the crease and hear/feel air blowing through it as I'm going down the road (weatherstrip is 100% intact on door), when closed looking at it from outside, it doesn't look like it's fits quite right. while the passenger side door looks perfectly fine. Second.. I changed my lock cylinder (new key) passenger side door took another key and apparently nobody has the spare key to the new drivers door, it possible to get the doors keyed to the new key I have for the ignition?
You can have a mobile locksmith come and have the doors keyed to the ignition , they can order or may have in stock, the cylinders to match the ignition. If the ignition is the original, then you can call with the vin number and that would make it that much easier on everyone. If the ignition has been replaced, you would need to find a serial number on the ignition cylinder, identification number what ever its called, then they can get the matching parts. Im going through a similar challenge with an acura i bought, its a chipped key though, the ignition was changed so the door key doesn't match ignition. He explained to me the basics of our problems.
Old Feb 1, 2021 | 06:59 PM
  #47
Venomouskev
Originally Posted by WTRBKT55
My 94 F150 XLT needs a new drivers door due to an accident (not my fault). It has a big hole in it and no body shop will touch it. I found a nice 93 black door (won't have to paint since my truck is black) but it's a 93 door. Can I swap in the 93 door and what are the differences since I'll only be swapping the drivers door. The guy at the junk yard said their not interchancgable. Thanks for any help.
so ive been reading up on the doors and glass for the f150. 92 through 96 are all interchangeable. I saw one thing that said, as long as the trucks are both the same style transmission. Oh, check the window to see if they are power or manual, the door panels are slightly different.
Blue oval obsessed
Paint & Bodywork
Dec 26, 2020 09:37 PM
corbins3853
Nov 28, 2020 08:32 AM
corbins3853
Nov 28, 2020 06:46 AM
arrowheadfred
34
May 19, 2011 11:15 AM
Gary G
Mar 6, 2004 08:22 AM
