Sorry buddy, you're out of luck, no superchargers. I think a few of the guys are trying to come up with a way to adapt one to fit. Its been awhile since I've been in this forum, I don't have a six anymore but i like to poke around.
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some 32" BFG Muds .
Pictures are in!!
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
I've never seen or heard of a supercharger that will work, but a turbo should be fairly easy to install. The easiest way would be to use a log type exhaust manifold from a non EFI model and bolt a turbo either directly to it, or make a short pipe to get it away from the engine a little bit. Run the turbine outlet through the core support to a PSD intercooler and then back through the core support on the other side to the throttle body. I'm thinking the turbo from a Buick 3.8 in a Grand National or Turbo Regal would be about perfect for this application.
