more questions
Old Nov 11, 2007 | 03:06 PM
countrysF250's Avatar
countrysF250
more questions
1990 F350 7.3L i have two questions the first is the overdrive light keeps flashing what would cause that and the second is the right side of the motor has a miss to it is this a injector problem or what and if so how do i find out which one it is
Old Nov 11, 2007 | 04:22 PM
starmilt's Avatar
starmilt
The easiest way to find your miss is to crack injector line loose this will make motor miss tighten back pepeat until you find a cylinder.that doesent change you motor.
Old Nov 11, 2007 | 09:33 PM
benwill1's Avatar
benwill1
The overdrive light flashing is due to the trans computer having a trouble code. Do a search for that on this site.
Old Nov 11, 2007 | 10:25 PM
PLC7.3's Avatar
PLC7.3
You can visit any Azone and they have the trans code tester........for free use usually.
A/Ox4
Oct 21, 2012 10:50 AM
krommag
Aug 25, 2009 04:49 PM
kadrocker
17
Apr 11, 2009 02:15 PM
guillermojm
Oil & Lubrication
Nov 11, 2005 01:38 AM
phonebooth
16
Nov 20, 2004 10:20 AM
