wiring
Old Nov 11, 2007 | 02:38 PM
76bigorangeford's Avatar
76bigorangeford
wiring
looking over the wiring on the 76 F150 i just got, and the battery keeps dieing, well there is a 2 amp draw when the truck is off, pulled all the fuses and nothing, so then i pulled this grey wire off the starter solinoid, and that was it, but when i do this the truck has absolutely no power to anything. they grey wire is spliced into the ig black with yellow stripe wire that comes off of the alternator? so waht is going on here?
thanks
Old Nov 11, 2007 | 02:40 PM
Mil1ion's Avatar
Mil1ion
Grey wire spliced into the main power wire ?
That's strange.
So ...How many wires are connected to that power lug ?
Old Nov 12, 2007 | 12:39 PM
76bigorangeford
the power lug ont he starter solenoid? it has the main battery pos. cable, the mystery grey wire, and then two others which are factory wiring
i know its really wierd
Old Nov 12, 2007 | 02:08 PM
Mil1ion's Avatar
Mil1ion
Is it actually spliced in or is it just wrapped in tape along side that black wire.
Take a closer look
Old Nov 12, 2007 | 02:19 PM
FESTER1st's Avatar
FESTER1st
I'm thinking grey wire is a possible replacement of a fusable link. If so your going to have to get into your harness a little deeper on this one.
Old Nov 12, 2007 | 02:35 PM
76bigorangeford
no ti is definitly spliced into the other wire with a connector and everythign, the grey wire does say fusible link all along its length but someone could have just used some random wire that they had laying around
Old Nov 12, 2007 | 02:57 PM
Mil1ion's Avatar
Mil1ion
actually no..... it has to be fusible link to prevent your truck from accidently catching fire.
where do the 2 other wire to the lug run to ?
Old Nov 12, 2007 | 06:32 PM
76bigorangeford
they run into the wiring harness im think i can check it out later, maybe one goes to the volt. reg. im not sure
thanks for the info guys
Old Nov 14, 2007 | 12:05 PM
76bigorangeford
any more ideas????
Old Nov 14, 2007 | 01:37 PM
Mil1ion's Avatar
Mil1ion
Get me a photo of it to look at .
Here's a schematic to show what should be hooked to that lug.
BigWhite76
Jan 23, 2015 05:16 PM
76F15OSuper
May 14, 2014 08:12 AM
staysbroken
Nov 18, 2010 09:05 AM
bulla
Sep 29, 2010 11:51 PM
