1999 f150 electronic shift problem
Old Nov 11, 2007 | 01:13 PM
chasboy's Avatar
chasboy
Angry 1999 f150 electronic shift problem
The other day when switching from 2 wheel to 4 wheel hih drive a load bang sound was heard from under the cab. The truck was in 4 wheel drive which was fine for the purpose it was intended for. When the need to switch back it took several attempts of rocking the dash switch to get it back into 2 wheel drive. Now when trying to put the vehicle back into either 4 wheel high or low nothing happens. Found that there is no power to either the electronic 4 wheel dash switch nor the transfer case shift motor. I have heard that Ford has been having problems with tranfer case motors but since I seem to not be getting electric power to either control that before I have the tranfer case motor replaced I'm wondering it could be something else. Also I've noticed that when I first start the truck I'm hearing a click sound from behind the dash . It clicks several times & then stops. Idon't know where to begin to find out where the power supply comes from that feeds these controls.
Also when all is said in done can the the transfer case shift motor assembly, if bad, be changed out by myself or does it need to be done by a Ford mechanic? You can also e-mail me at chassue57@bellsouth.net if so desired.
Thanks
Old Nov 11, 2007 | 04:50 PM
Ultramagdan's Avatar
Ultramagdan
Welcome!
To get the help you need you will want to post in the tech forums. Click on the Forums tab at the upper left and scroll over the boards. The 97-03 is a good one to post in with lots of great help there. For local information be sure and stop in your state chapter: https://www.ford-trucks.com/forums/forum116/
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
Dec 27, 2012 03:38 PM
paul burak
New Member Introductions
Nov 25, 2007 09:11 AM
jrnriver
May 13, 2007 03:20 PM
bscruggs
Nov 4, 2006 03:53 PM
sierraben
Jun 19, 2006 06:48 PM
