Fuel Starvation?
Old Jun 27, 2002 | 03:23 PM
desperado_18_2000's Avatar
desperado_18_2000
Fuel Starvation?
Buddy of mine has a 300 with a fuel problem. Give it gas it stumbles, let it idle, and it just idles with no problems. its kinda an emergency situation. can someone tell me how to fix this? thanks in advance.
Old Jun 28, 2002 | 01:04 PM
Vampiro's Avatar
Vampiro
Fuel Starvation?
maybe the fuel filter is clogged
Old Jun 28, 2002 | 01:05 PM
SPROCKET's Avatar
SPROCKET
Fuel Starvation?
try replacing the fuel filter
Old Jun 28, 2002 | 02:36 PM
tetraruby's Avatar
tetraruby
Fuel Starvation?
What year truck? After filter, I recommend checking the carb. May need a float adjustment or new pump.
Old Jun 28, 2002 | 04:47 PM
desperado_18_2000
Fuel Starvation?
call me old fashioned, but we checked the filter, and it was pouring clear gas... it isn't blocked. put that back together and it kept starving under load, so i finally took some transmission fluid and poured it into the carb. i don't know why it worked, but it cured the problem, but made it smoke like a tar kiln. it runs great now though. doesn't flood at idle and doest hesitate. can someone explain this to me?
Old Jun 29, 2002 | 01:59 AM
whitebenz's Avatar
whitebenz
Fuel Starvation?
Atf is IMHO the best carb cleaner in the world. It also cleans valves etc. You probably had something gummed up and the atf cleared it out. Try putting a quart or so in the tank once a month. You will be amased at how well it works. It will stop smoking (you probably have some atf in the cat.)
dj
Old Jun 29, 2002 | 04:15 AM
AKFord's Avatar
AKFord
Fuel Starvation?
drad
19
Jan 17, 2013 12:27 PM
towmaster
Mar 14, 2011 09:40 AM
7677mess
Dec 18, 2004 06:20 PM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 16, 2004 01:59 PM
