Stroke died the day...
Old Nov 10, 2007 | 03:30 PM
Stang5lgt's Avatar
Stang5lgt
Stroke died the other day...
I was driving my Duty and came upto a stop light and truck died. Would not start. Started today but is idling all crazy and sounds bad. The check engine light is on. Code I pulled is P0603 something about KAM. I am puzzled.
Old Nov 10, 2007 | 03:48 PM
nlemerise's Avatar
nlemerise
  • Possible causes:
    • Battery or PCM has been disconnected.
    • Battery cables loose or poor connection.
    • Battery discharged.
    • Open in KAPWR circuit.
    • Blown fuse.
    • PCM.
    CHECK 5 AMP FUSE #2
  • Key off.
  • Remove and inspect fuse 2 (F-Series) If fuse is blown, replace it.
  • Measure voltage between fuse B+ terminal and ground
Old Nov 10, 2007 | 04:03 PM
RogueSpear2023's Avatar
RogueSpear2023
You may want to replace your CPS, it's a common problem, with the PSD's, They are fairly cheap about $30. This is what usually causes a no start, or stall.
Old Nov 10, 2007 | 04:31 PM
Stang5lgt's Avatar
Stang5lgt
I just put a new CPS on it 10 miles ago.
Old Nov 10, 2007 | 04:40 PM
Stang5lgt's Avatar
Stang5lgt
Originally Posted by nlemerise
  • Possible causes:
    • Blown fuse.
    • PCM.
    CHECK 5 AMP FUSE #2
  • Key off.
I checked the fuse. Reset the codes started the truck again idled all crazy again. So I put it in gear and moved truck a little the idle came into normal speed. So let it idle for awhile. Shut it off and pulled two new codes. p1209 and p1211. Seems to be running good now but the Check engine light is still on.
Old Nov 10, 2007 | 04:49 PM
ron's power stroke's Avatar
ron's power stroke
you can check your codes here..
https://www.ford-trucks.com/article/...sel_Codes.html
P1209 Injection Control System Pressure Peak Fault
P1211 ICP Not Controllable - Pressure Abow/Below Desired
Old Nov 10, 2007 | 04:53 PM
Stang5lgt's Avatar
Stang5lgt
Might just drop it off at the diesel shop and let them look at it.
Bobby Maguire
Feb 22, 2014 05:14 PM
luvemhot
13
Jul 26, 2013 01:21 PM
blade fever
Jan 23, 2012 01:08 PM
Jayme Duty
Apr 26, 2010 12:54 AM
ChevDog1
16
Sep 7, 2004 03:34 PM
