best lift?
Old Nov 9, 2007 | 10:58 PM
97stroker-kt's Avatar
97stroker-kt
best lift?
hey guys, i have a 1993 F150 xlt sc sb 4x4 auto. i was just wondering whats the best cheap lift out there? my truck ahs the stock ford front and rear, w/ 31"s. thanks in advance for the help, appreciate it.
jason
Old Nov 9, 2007 | 11:12 PM
khadma's Avatar
khadma
Carpenter Local 745
Rough country sells suspension kits for around 500.00 and they are a sponsor of FTE.
There are many, many companies that still offer systems for these trucks
Skyjacker
Pro comp
Rancho
Superlift
just to name a few.
Some companies offer extended radius arms with their kits and add a leaf rear springs - These options are the best to me, but increase cost to the kit.
Old Nov 10, 2007 | 11:01 AM
lostin90s's Avatar
lostin90s
Like he said . I like the extended rad arms myself . And used to run Ranco. I would avoid the block rear lift kits . I had problems and was not a offroader. Good luck.
How high you want and tire size. You can make 33" fit nice with the 2" lift coils and add a leafs. Dont for et the Chamber kit with em.
Old Nov 10, 2007 | 10:22 PM
97stroker-kt
im not looking to sky my truck, just a little height is all, enough to up the tire size a little (32's-33's), i priced a rough country 1.5" leveling kit, which was pretty reasonable, so ill check out the others Khadma listed, thanks guys.
jason
Old Nov 10, 2007 | 10:34 PM
jk89cat's Avatar
jk89cat
i would go skyjacker, superlift or rancho , as those are the ones with the extended radius arms, really makes a huge difference as this is how my truck is set up, also , buy rearched rear springs if its an option, its one of the best things i ever did to mine. my truck had 33s with the rancho kit and fit well. the add a leafs had cracked so i opted for rough country easy rider rearched springs, i went with f250 4 inch . absolutley love how it handles and i can put a car tralier with a full size car and she dont squat !
Old Nov 10, 2007 | 10:38 PM
khadma's Avatar
khadma
Carpenter Local 745
You can basically run 32-33s without a lift.
The 1.5 leveling kit will work for you, as long as you do not do some hardcore wheeling. This would cause tire rub up front.
Check out the other companies and keep us posted.
Have fun working on your truck.
Old Nov 12, 2007 | 05:00 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
You can also check out our shop's lift kits to compare prices and customer reviews here: http://motorhaven.autoanything.com/category_rewritten.aspx?silo_name=suspension-systems&c_id=50625
Old Nov 12, 2007 | 05:22 PM
khadma's Avatar
khadma
Carpenter Local 745
In another post, someone was looking for softer springs for a 2000 2wd Ranger. I'll look for it and PM you with the thread.
I may put a 2.5 to 4 in lift on my 96 FSB, thanks for the info.
Is there an FTE discount with your company too?
Old Nov 12, 2007 | 07:25 PM
ToughBuiltFord
FTE Sponsor
Thanks, I just got your PM. We are offering $20 off orders over $200, just enter the code "FTEDEAL" at check out. This offer is good for any brands we are allowed to discount.
I will check out the thread. Let me know if you have any questions.
