transfer case not engageing
Old Nov 9, 2007 | 01:05 PM
goofin's Avatar
goofin
just replaced m5r1 5 speed and new clutch. everything is working fine except that no 4 high or 4 low. both lights will flash 5 to 6 times at start up and while driving down the road. of course its electronic control. maybe control module bad? any ideas?
Old Nov 9, 2007 | 01:49 PM
wendell borror's Avatar
wendell borror
Electric shift motor, it's the most common problem with the push button t-cases other than the vacume hubs. Try cleaning it first and see if that helps.
Old Nov 9, 2007 | 04:08 PM
Rockledge's Avatar
Rockledge
If your truck is a '98 (why make us guess?), it would be worthwhile to check all the fuses related to the 4WD system (#s 9, 10, 26, and 27 in the interior cab fuse box, and also fuse # 3 located in the power distribution box under the hood).
Old Nov 9, 2007 | 06:32 PM
goofin's Avatar
goofin
thanx for the info guys, as soon as it stops raining ill check out the fuses. rockledge, sorry i forgot to add the pertinant info, old age is a pita.
Old Nov 10, 2007 | 08:23 AM
goofin's Avatar
goofin
thanx guys, motor is sticking. wack it with the dead lo hammer and it works. found a new one for 100 bucks
Old Nov 10, 2007 | 05:12 PM
ratchet44's Avatar
ratchet44
Right on, good to hear you found out what the problem was. If you 'new one' is actually a used one from another truck, may consider cleaning that bad boy before you bolt 'er back in, to prevent future problemos. But, if you got a new factory model, good on ya! I hear those things usually go for a lot more these days.
Old Nov 10, 2007 | 08:58 PM
wendell borror
99% of the time it is the shift motor except for the 98-2000, then 90% of the time it's the pulse vacume hubs.
