engine tune up
Old Nov 9, 2007 | 07:57 AM
johng5603's Avatar
johng5603
engine tune up
I have a 04' f-150 with around 53,000 miles, I am curious as to when I should change my plugs. I have noticed that I don't get as good of gas mileage as I used to especially on the freeway. I am aware of each plug having its own coil but how difficult is it to remove the coil in order to change the plugs and if I do decide to do it should I disconnect the battery first in order to prevent a possible spark in the wires. I would rather take it to a certified technician but I am sure that will be very expensive.
Old Nov 9, 2007 | 10:00 AM
CougarXR02's Avatar
CougarXR02
change them anytime. But I would do it before 70,000. This is from experience. Check over in the F-150 threads about the coil questions.
Old Nov 20, 2007 | 12:43 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from Towing forum.
Old Nov 20, 2007 | 02:03 AM
Fosters's Avatar
Fosters
what motor do you have? the 5.4 3v has some problems with these plugs... you may wanna do a search on these forums
Old Nov 20, 2007 | 06:53 AM
db_tanker's Avatar
db_tanker
the 5.4 3V will need to be changed for sure...as what Fosters said...search on here and you will find the TSB detailing the process for this.
if you have a 4.6 then you can wait till around 100k as this is a regular style 2V head and will not be that big a deal to change IMO...just remember...one at a time and take your time doing it.
Old Nov 20, 2007 | 12:08 PM
MBBFord's Avatar
MBBFord
He has COPs, so it's more than likely the 5.4 3V.
Read up a little, get the TSB and follow it to the T.
I've got about 1,200 mile till I have to change mine, hopefully nothing goes wrong, but I know I'll break at least one.
Old Nov 20, 2007 | 03:48 PM
db_tanker's Avatar
db_tanker
my 4.6 has COPs as well. the 4.2 still has plugs and remote coils though.
Old Nov 21, 2007 | 10:39 AM
BrianFX4's Avatar
BrianFX4
I just had mine done at 65k at Omeara Ford in Denver, CO and it cost me $189.00 and they didn't break a single plug.
They kept it all day from 8am to 5pm so they could take their time and not break a plug. If they would have broke a plug it would have cost me $25 a plug for extraction...which is not bad considering what some people have had to pay.
