will this pass emissions?
Old Jul 21, 2002 | 03:47 PM
MIKE 351's Avatar
MIKE 351
i was thinking about a v8 but after talking to several people i may stick with my 300/6.but i am wondering if it is possible to pass emission with a cliffy/offy intake and headers and a 390cfm 4bbl and a 264 cam .tailpipe sniffer only ,no visual and no dyno.thanks mikeP.S. this is in a 79 ford f150 4wd
Old Jul 21, 2002 | 04:26 PM
tetraruby's Avatar
tetraruby
>ford f150 4wd
Mike, best answer I can give you is to check with a local technician. A lot of places do "pretests." For example, here in CA when I brought my '79 in to be smogged I had a prestest done. It costs more, but will tell you what you need in order to pass without sending the info to the state with a failing result. I would have failed because I was running to rich to pass the tailpipe test. I would have two concerns if I were you. 1) I assume the thermactor system is no longer (if it was ever installed). Your state may require a stringent enough spec that having the extra O2 to the cat will help. 2) I also assume you haven't fabbed up some sort of EGR to work with your setup...if the state tests for NOx out of the tailpipe - you may be screwed. If the cam was degreed correctly and the carb is in tune you may fare well. Call your local inspection station and talk to them, inquire about a pretest. Best of luck.
Old Jul 21, 2002 | 04:33 PM
chuckman's Avatar
chuckman
Theoretically speaking, anything you do to the intake or exhaust is not emissions legal unless the process has been approved by the smog *****. But in terms of testing, you should be ok unless you're running rich or or lean. They do visuals around here, and all they check for is if there is the presence of cats, so you should be jsut fine.
Old Jul 21, 2002 | 09:48 PM
82F100SWB's Avatar
82F100SWB
BAD RONALD
Mar 7, 2012 08:16 AM
amsk8er1983
Jan 13, 2010 10:56 PM
superduty4x4
Sep 2, 2008 05:14 PM
dallas lewis
1978 - 1996 Big Bronco
Jan 12, 2006 05:28 PM
steamer1234
Aug 21, 2004 07:27 AM
