Current Draw
Old Nov 8, 2007 | 02:15 PM
fuzzy1626's Avatar
fuzzy1626
Question Current Draw
Need to know max current draw through positive cable when truck is off doors closed hood open. Clock and under hood light would be only draw. Correct? Having battery problems since first cold snap.Test at Advance showed one battery very low but good, other only needing small charge but good. I have my doubts.
Old Nov 9, 2007 | 04:11 AM
PLC7.3's Avatar
PLC7.3
KAL memory in the radio too...
Old Nov 9, 2007 | 08:41 AM
starmilt's Avatar
starmilt
both batterys need to be up batterys will draw off each other equalizing themselves.
this is why you allways replace both at same time.
Old Nov 9, 2007 | 12:37 PM
tbone91's Avatar
tbone91
Just a thought, you may have bad cables. With everything hooked up, and the engine running, check both batteries separately (meter leads to the posts on the same battery, not the clamps, frame or block). If they read different voltages, something is wrong with the cables...
Old Nov 9, 2007 | 02:48 PM
fuzzy1626's Avatar
fuzzy1626
Thanks all. Will try the cable test. Getting ready to order new 2/0 cables from CustomBatteryCables.com if I have to get new batteries. I'am pretty sure the batteries won't "hold" a charge anymore.
regulate34
1983 - 2012 Ranger & B-Series
Jul 18, 2014 04:45 AM
ferdly1
Mar 25, 2014 05:11 PM
Cole Neese
107
Feb 22, 2014 11:40 PM
FastFiveO
Apr 10, 2013 03:40 AM
andym
Electrical Systems/Wiring
Apr 5, 2005 06:34 PM
