Sponsored by: Real Truck
2008 F250
Old Nov 9, 2007 | 05:19 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Originally Posted by redford
The frontal area of my trailer is small?
It's taller than my truck (at least 7 1/2 feet), 8 1/2 feet wide and as aerodynamic as a brick! It's an enclosed 28 foot car hauler with an optional 6 1/2 foot ceiling (floor to roof).
Where do you guys come up with this stuff?
Thats' not frontal area --this is frontal area - top of cab comes only to the bottom logo.....
Old Nov 9, 2007 | 05:32 PM
tex25025's Avatar
tex25025
Originally Posted by HorseyHauler
I agree, towing 2H GN with LQ (9K+) and though the trailer front has a narrowing nose (5 ft.) it is still almost eight feet wide and ten feet tall. The short bed on the truck helps with the handling on the highway and can still get 75 degress plus angle between truck and trailer. Also, makes a difference when the 1300 lb. butthead starts shifting his weight in the back. Have friends who haul four or more horses and just know they are coordinating their efforts. Hauling a live load is a different experience.
The 4.10 rear gives the extra power needed to overcome the wind.
I have to tell you 4.30 really helps out alot more then the 4.10 gears in my old truck for hauling horses. If I'm hauling two horses, I'll get out the little steel 2horse gooseneck, but if I'm hauling for people at the barn, I drag out the 6 horse and that is a killer. As to Redford, I believe that a 5.4 in a 350 SRW and especially in a DRW needs to have 4.10 gears as there is little doubt in my mind that if a 5.4 had to haul what I needed to haul it would struggle quite a bit. Now for the average joe blow, I doubt it would need the 4.10s, but the 5.4 is going to need help sooner then the other two in the towing department if your towing some heavy loads(not necessarily often enough to warrant a diesel or v10, just heavy loads).
Old Nov 9, 2007 | 06:37 PM
swann79's Avatar
swann79
Get the 4.10s. The first time you pull that heavy boat uphill you will be glad you did.
Old Nov 9, 2007 | 06:55 PM
four4x4fords's Avatar
four4x4fords
Good point about frontal area.
I have a pull type 8000 lb. Toyhauler that has a rather large frontal area. I have 3.73 gears in my V-10 powered SD that tows it well and it pulls hills fairly well and I was content to leave it alone until next year and then do more upgrades. And then I had to tow in a significant headwind for about 25 miles. After running in second gear for a large portion of that 25 mile stretch, I am now determed to install 4.30 gears before my next long trip.
I had a much smaller and lighter travel trailer when I bought my truck. Due to a fire in the refrigerator, it needed to go and I figured if I was getting a new trailer, I mght as well get a bigger one.
Point being you cannot predict the future, but you can plan for it by buying a bit more truck that you need, just in case...........
Old Nov 10, 2007 | 12:46 AM
capn kirk's Avatar
capn kirk
Longer wheelbase will always help with towing and you get used to driving it fast if you have ever owned a truck before and 4.10s will make your life easier any time you tow or meet with alot of hills
ESOF never let me down in 3 different trucks we have or to be honest on any of the plow trucks we had at my last company, but you do hear of problems with it.the only common issue is the hubs not locking, if this is an issue replacing with manual hubs is easy. i say the main issue is you never hear about when a plane lands safely
Old Nov 10, 2007 | 03:39 AM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by STEELIE ADDICT
Thanks to all for the input. It will be my daily driver so the 5.4 is almost mandatory. I tow a large boat (6000-7000 lb.) infrequently and a small boat (800-1000 lb.) often.
Sounds like all you need is an F-150. I towed 7000lbs worth of horses and trailers w/the 3V 5.4L and 3.73's. Lighter truck makes better use of the engine. F-150's can be had for less dough, too.
Old Nov 10, 2007 | 06:56 AM
tex25025's Avatar
tex25025
The only problem with that is that he is only going to have the tranny that just locks out overdrive(unless they changed it, I really had no need to keep up with the 150s so I don't know) and I have seen people ruin trannys even when they have locked out overdrive when they hauled. The one that I would be concerned about is the large boat. Not knowing the terrain that he has to deal with while hauling that also affects how well the 150 is going to handle that large boat as well. Not knowing certain variables I don't think we can accurate advise him on rather or not a 150 is sufficient. While I agree with the 5.4 engine in his case, a lighter truck means it can handle a lighter load and if it has to deal with a harsh environment pulling(hills and high winds will rock that lighter truck as well etc.) then that's going to show up while pulling and I would be afraid that he would regret getting that lighter truck.
Old Nov 10, 2007 | 07:32 AM
swann79's Avatar
swann79
Good point, Monsta. I agree. I regularly towed 7000 lbs with my '04 F-150. It can handle it. Mine was a Screw, rated to tow 8200 lbs. Never any troubles. I just needed more payload capacity, and more oomph for the mountains, so I upgraded.
Old Nov 10, 2007 | 08:18 AM
tex25025's Avatar
tex25025
That's what I'm talking about though, not knowing the terrain that he has to haul thru, how can you really say that a light truck like the 1/2 ton could do it? I have had a 150 empty going thru some of the hills here(worst 2 wks of my life being without my diesel truck) and it struggled up those hills just to maintain speed(which was the legal speed limit), I would hate to see what it would be like hauling 2 horses with a bumper hitch thru those some hills. I know people do it for various reasons, but I just don't think it's the best choice, it might be the only choice you have and it's better then nothing, but it's not the best choice out there.
Old Nov 10, 2007 | 09:06 AM
redford's Avatar
redford
FTE Leadership Emeritus
Your comparing apples and oranges. Even though your trailer sticks up more, 5th wheel towing brings it much closer to the cab, which helps a lot. You can't directly compare the frontal area of a 5th wheel trailer and the frontal area of a conventional trailer.
Think of it this way. The air moves up to go over your cab. As it comes back down you have this trailer to fill the low pressure void. Air continues upward to go over the trailer. It'd be somewhat like drafting in NASCAR.
Now, on mine, the air moves up to go over the cab, there's nothing behind the cab to fill the void so the air moves back down, then meets the front of the trailer where it has to move up or sideways.
Old Nov 10, 2007 | 09:10 AM
msalyer's Avatar
msalyer
My TT (not fith wheel) front is over 10' high by 8' wide, quite a bit higher than yours. Believe me that makes a big difference. My TT weighs 6500 pounds and pulls pretty hard. I have pulled flat beds that weigh 10,000 that don't pull as hard, but whatever.
Old Nov 10, 2007 | 11:24 AM
ericsmith32's Avatar
ericsmith32
I was thinking along the same lines as Steelie Addict. The heaviest thing i'll be towing is a 33 ft fiver which weights 11-12k on occasion but usually it would empty or towing a trailer no more than 5-6k. I've pulled the fiver with a 5.4 2v with 3.55's and it was able to maintain 60-65 even on steep hills.
My only worry is what tranny? I usually abide by the rule of small engines but with manual, automatics are usually dogs with the smallest engine in the line-up. My wife is against the idea of having a manual in my next truck though. I've driven a V10 2v with the 5r100 and it was awesome.
But after adding the extra weight of a extended cab and 4x4 how much of a dog would the auto be? The rearend would be 4.11's. The model would be a XL so not alot of added weight from accessories. 5r100 might of closed the gap between auto and manual is my thought. I might get lucky though and the F-Series would be easier to drive than my 5spd Ranger, she hates that thing.
Old Nov 11, 2007 | 07:12 AM
  #28
alchymist's Avatar
alchymist
"Mifflin Clay"
Might be, but that extra 5-6 feet of trailer sticking up above the truck doesn't help. All you 5th owners - take a big handful of styrofoam peanuts and throw them in the truck box, then go down the road and watch them - so much for the trailer filling the void. I'm told that a louvered tailgate helps smooth out the airflow, but haven't tried one yet. Should I get one I'll popcorn test it.
In the meantime heres some info on trailering & saving fuel I found interesting: http://www.landlinemag.com/Archives/2006/May2006/bottom_line/more_miles_less_fuel.htm
Old Nov 12, 2007 | 09:48 AM
  #29
STEELIE ADDICT's Avatar
STEELIE ADDICT
To answer the question of terrain, I live in an area where there are a lot of hills and also some mountain passes. I don’t tow over the passes very often, but I do on occasion. I feel more confident with the tranny in the Super Duty also. It looks like the F150 extended cab is only about 200 lbs. lighter than the F250 regular cab. I can’t imagine that making a huge difference in mileage. The cab extension is what I am giving up by going to the Super Duty. I am trying to keep cost down a little. The other aspect of the situation is that I really like the Super Duty better.
Old Nov 12, 2007 | 11:25 AM
  #30
Monsta's Avatar
Monsta
Sit. Stay.
Actually that's everything then.
