expedition or explorer?
Old Nov 8, 2007 | 01:04 AM
newbie10's Avatar
newbie10
Exclamation expedition or explorer?
I have a 24' pontoon and trailer. However, I do not have a vehicle to tow it with. I believe the weight of the pontoon is anywhere between 3-5000#. My question is, I am thinking about buying a used expedition for this purpose- would this do the job or can I get away with an explorer or even an f-150? Thanks!
Old Nov 8, 2007 | 01:13 AM
andym's Avatar
andym
Expedition and an F-150 are the same chassis and *general* towing capability. Either one would work fine if properly equipped, i.e. don't try it with a 4.6l automatic F-150.
My rule of thumb is never tow anything with an explorer. They're too unstable and too many (especially inexperienced) people have gotten hurt or killed trying it.
Old Nov 8, 2007 | 01:18 AM
newbie10's Avatar
newbie10
thanks for that info since I had begun leaning toward an explorer but now will stick with my original thought of an expedition!
Old Nov 8, 2007 | 07:53 AM
tomtoc's Avatar
tomtoc
i always thought "go bigger" myself. better safe than sorry.
are the newer explorers any better at towing that the older ones (99ish and lower). they seem a lot bigger. my sister has an 02 explorer and my mom has a 99 expedition. obviously lots of differences, but they seem a lot closer in size than the older explorers were
Old Nov 8, 2007 | 08:16 AM
MisterCMK's Avatar
MisterCMK
The Explorers are fine for towing. My family used to have a 97 Explorer with the 4.0 SOHC and a 5spd auto. We towed our pop-up trailer all over the country without a hiccup. FWIW, we had the "exploding" Firestone tires on it too and never had a problem.
I've towed with my 1992 Explorer with the 4.0 OHV and a 4spd auto without a problem either. If anything, the older trucks are better as they have a solid rear end.
How far are you towing the pontoon? How much does it weigh?
Old Nov 8, 2007 | 08:56 AM
albran's Avatar
albran
Yep Yep and Yep
We had the "exploding" Firestone's for a few k miles, Ford gave us some Bridgestone's, I always assumed they were the same tire, just said Bridgestone on the side so I watched the air pressure, no problems.
A V6 Explorer will be maxed out pulling your boat ESPECIALLY when you add wife, kids, ice chest, extra gas etc etc.
The V8 will have NO problems.
Old Nov 8, 2007 | 10:45 AM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
Originally Posted by albran
Yep Yep and Yep
Adding those items will sure add weight but not nearly enough to put you over weight....... Until you add the appropiate amount of beer. Then you may need an SD
Old Nov 8, 2007 | 05:10 PM
elmo8641's Avatar
elmo8641
the newer explorers are not the same as the ones with the tires. my wife has a 2004 and i used it to tow alot of things before i got my truck. it would pull the boat with no problem at all. i do have a f250 and use it for all the towing so she could have it back.
Old Nov 8, 2007 | 05:52 PM
newbie10's Avatar
newbie10
In responce to MisterCMKI would only be towing for about 50 miles round trip, however, I live in the mountains of western NC and those miles are steep and winding. The pontoon itself, I am guessing is anywhere between 3,000-5,000 with the trailer included.
Old Nov 8, 2007 | 09:32 PM
dodmort's Avatar
dodmort
I have a 26 ft pontoon with drive on top trailer which i hate. i am pretty sure it is a dorsey trailer and sanpan pontoon.
the boat and trailer are heavy. very heavy.
and tongue weight is heavy also.
i do not think my wifes new expedition would handle it at hiway speeds. have never tried since my lake house is .25 miles from water. so never go fast. launch with 68 bronc. and it takes all it can in low to do this. but yours may not be this type rig.
Old Nov 10, 2007 | 12:23 PM
RogueSpear2023's Avatar
RogueSpear2023
Go with either the expedition or an F-150, and explorer is just to small of a vehicle to to a boat like that. You could tow a small fishing boat or a small pup-up camper with an explorer, but not much more. My Parents own and Explorer, Escape and a F-150. We pull the our pontoon 22' regularly with the F-150 or my F-350, but I would not even think of trying it with anything smaller, or else your chancing causing damage. I also think it would be quite difficult for an explorer to pull it out of the lake. Explorer's are good people haulers, for driving in bad conditions, and towing small loads. If you want to haul large loads like a pontoon you want an expedition or F-150, you also have to realize that the pontoon is not the most aerodynamic either, so it also creates a lot of drag.
Old Nov 10, 2007 | 02:22 PM
skilife17's Avatar
skilife17
I'd say go with an Expedition or F150. Since you said you are in the mountains get the 5.4. I have a 4.6 in my 97 F150 4x4, and tow around the same weight on occasion. I have no problems with my truck only because i rarely have any hills to contend with.
Old Nov 10, 2007 | 03:26 PM
newbie10's Avatar
newbie10
Just wanted to thank all of you who posted an answer for me. I am quite amazed and grateful for all of the help and thought that went behind each reply and didnt want your acts of kindness to go without recognition. Too bad this web-site doesnt extend beyond the keyboard of all the PC's in use here.....the world could certainly use the genuine helpfulness that is exhibited in venues such as this. Thanks again!
Old Nov 10, 2007 | 03:44 PM
RogueSpear2023
Feel free to ask any other questions you have, we will be glad to answer them.
ah1988
Jul 2, 2012 09:52 PM
wzabawa
1997 - 2003 F150
Jul 23, 2008 05:45 PM
dyoung14
Apr 25, 2008 08:28 PM
newbie10
Ford vs The Competition
17
Nov 17, 2007 06:01 PM
DeckedoutF150
Ohio Chapter
Jul 19, 2006 04:35 PM
