Just hit 180k!
Old Nov 7, 2007 | 07:00 PM
NeXtras's Avatar
NeXtras
Just hit 180k!
So my 1994 Flare Side just chugged its way to 180,000 miles! My small block 302 is holding together nicely!
My tranny has been rebuilt and only has about 30,000 miles on it so no worrys there. Other than normal wear and tear and regular oil changes is there anything i should be worried about?
Old Nov 7, 2007 | 07:06 PM
hodernyf150's Avatar
hodernyf150
no if everything is working good. no knocking or any kind. i have 180k on mine and it is running like a champ
Old Nov 7, 2007 | 07:11 PM
ACarbone624's Avatar
ACarbone624
Time to update your sig!
Old Nov 7, 2007 | 07:27 PM
rikard's Avatar
rikard
I'll be turning 180k by the end of the week. Running strong looking good.
rikard
Old Nov 7, 2007 | 08:28 PM
brown 4x4's Avatar
brown 4x4
I remember turning 180K almost two years ago. Nothing to worry about if it's doing good now. I've got a couple minor leaks--oil pan gasket and timing cover gaskets--but other than that it's running flawlessly. Congratulations!
Old Nov 7, 2007 | 09:12 PM
builtfordtough13's Avatar
builtfordtough13
I just hit 150,000 miles about a week ago, so far no problems since I bought it at 75,000, except freeze plug blowing out. Other than the rust over the rear wheel wells it is almost absoulutly perfect.
Old Nov 8, 2007 | 01:06 AM
Jason Lewis's Avatar
Jason Lewis
96 302 4R70W 3.55
123,000 Miles "stock Waterpump" (Oil Pan Leak) (Rear Main Leak)
Trans still works great no probs !!!
Old Nov 8, 2007 | 05:40 AM
NeXtras's Avatar
NeXtras
Originally Posted by Jason Lewis
96 302 4R70W 3.55
i dont care whats wrong with your truck its still amazing. Sheer beauty man, sheer beauty
Old Nov 8, 2007 | 06:29 AM
92F150Flare's Avatar
92F150Flare
169K on my 92.........5.0 and the trans are doing great.......(knock on wood). Might use/leak a quart between oil changes but no big spots under it so I'm good.
Passenger window motor gears are another story though.......*sigh* I really need to fix that.
Good ole trucks!!
Old Nov 11, 2007 | 06:21 PM
jonathandennell's Avatar
jonathandennell
182,000 on mine.
Just replaced the O2 sensors, and did a high milage valvoline 10-40, motocraft oil and fram air filter change.
Only seems to be rear main seal and oil pan leak, and a little bit of a rough idle. Nothing else though.
Old Nov 11, 2007 | 09:34 PM
Dustin1690's Avatar
Dustin1690
Congrats i wouldnt be too worried if it runs good drives good and no weird sounds
Old Nov 12, 2007 | 08:57 AM
NeXtras's Avatar
NeXtras
i just put in the Engine Restore to the oil and added Techtron to the gas. The restore seems to work pretty dam fast, only had to drive 5 miles and i noticed a difference in accel.
Old Nov 12, 2007 | 05:02 PM
lostin90s's Avatar
lostin90s
I got 170 something on my truck New motor at 120000.And no it wont see another 100000. Sound like diesel when it cold . . 2 rebuilt e40ds,Due to shop stupidity .
Other than the last 2 I have got 200000 out of the old 302 .
Old Nov 12, 2007 | 05:33 PM
Linemo's Avatar
Linemo
306650 on my 1996 heavy F-250 4x4 rebuilt E4OD at 255,000 but she runs great good power no smoke or oil comsumption and will get 13-14 mpg on 285-75-16 pro comp all terrains my has mostly road miles but I will hop right in her and go anywhere the secret oil,air,fluid changes and fixing things before they break
Old Nov 12, 2007 | 06:55 PM
945SPD's Avatar
945SPD
Nextras,
Congrats! Mine just turned 144,000. Also a 5.0. She's a flareside w/the supercab and 4 wheel drive. Truck totally bonestock and I'm leaning towards improving the sound/look of the exhaust on her. The motor/exhaust is just too damn quiet. I've got to look at the tach to see if she's running. I'm grounded with just enough info to realize there's a lot of hype on horsepower claims improving the exhaust. I'm thinking of just a catback system and noticed you did this. What size pipes did you end up with after the muffler? With this small block, I'm thinking a 2 1/2 inlet muffler and dual 2 1/4" outlets. Toying with having both pipes run alongside each other and dumping at a 45* behind the pass rear wheel. Not going to touch the motor at all (don't attempt to fix what ain't broke). Like others here who are getting great service from their trucks, the key is maintaining all the fluids and changing them regularly.
Regards,
Jim
