Mods for Towing Performance
Old Nov 7, 2007 | 03:44 PM
tex25025's Avatar
tex25025
I'm looking for some ideas of what to do to my truck to better improve it's towing abilities or just to help with longevity.
Two mods that I'm thinking about in the future are an a/m fuel pump(maybe a FASS system) and/or an upgraded turbo(should I do vgt or fixed? I'm torn because I like the ability to use the vgt as an exhaust brake, but if it's better to go non-vgt for towing then so be it). I'm sure also I'll need to splurge for a more bulletproof tranny sometime soon as well. Anybody have ideas of what else I could do to make it last longer and be a more efficient hauler?
Old Nov 10, 2007 | 07:55 AM
flathead95hp's Avatar
flathead95hp
Depending on the type of towing you are going to do, I would start with a good trans cooler. Towing can be pretty hard on the transmission and you wouldn't want to blow it out by getting too hot. Hope it helps.
Old Nov 10, 2007 | 08:22 AM
tex25025's Avatar
tex25025
The majority of my hauling is with horses ranging from a 2 horse gooseneck trailer(steel) to a 6 horse gooseneck(also steel). I have looked into tranny parts, I just haven't seen many rec's for each of the products except what it on the sites which tends to be a sales pitch. Any that you have had good experiances with or have heard good things about from other people?
Old Nov 10, 2007 | 08:32 AM
flathead95hp
There are a couple of different sites to check out trans coolers www.nextag.com and www.tciauto.com/Products/Cooling will give you stats of different coolers and how they rate. Hope it helps.
Coronado
Aug 4, 2014 07:18 AM
ivory-tower
Jan 17, 2013 08:00 AM
04redstroker
Sep 27, 2009 11:06 PM
texans
Apr 4, 2009 03:14 PM
Dustball8504
Sep 27, 2008 07:12 AM
