vgt? Non vgt?
Old 04-04-2009, 06:44 AM
texans's Avatar
texans
texans is offline
vgt? Non vgt?
what are the pros and cons to the vgt turbo? I think I may get a a/m turbo this summer some time. Don't know much about these vgt turbos
Old 04-04-2009, 10:15 AM
tex25025's Avatar
tex25025
tex25025 is offline
Pros:
Able to use it as "Jake Break"
In theory, due to the VV able for one turbo to act like two sequential
Don't have to worry about programming the VGT sensor to shut down
Cons:
More parts to break down(this includes a lot of mini items under this general heading)
Personally I would go with a non-vgt turbo(as I have), especially if your a tow'er or just want to have a fast ride, if it's just DD street use, you might be able to argue a/m VGT turbo then.
Old 04-04-2009, 12:34 PM
texans's Avatar
texans
texans is offline
thanks tex I was hoping you would chime in here. Yes I want my truck to be fast. I also pull a heavy fifth wheel now and again. What I want is to enventually get 500-550 hp out of her. I'm trying to use your siggi as a guide line. I plane to do the turbo, injectors, rr, fass, and arps with egr delete some time this summer
Old 04-04-2009, 03:14 PM
tex25025's Avatar
tex25025
tex25025 is offline
I would do the non-vgt turbo with what your wanting to do. What I like about the turbo that I have for towing purposes is that it's able to "hold" egt's fairly constant. In other words, if your holding 5-10 psi of boost and going up a good grade of hill, it will hold onto egts at around 1100 even though you may actually going a little bit quicker going up that hill. As long as your pushing atleast 5-10 psi of boost that will help keep egts within check. Atleast that is what I have noticed when I'm hauling horses up some good size grades.
amdriven2liv
11-08-2018 02:21 AM
Knucks
03-26-2017 06:52 AM
j4henry
04-17-2012 09:51 PM
f350fixaliter
11-30-2010 08:35 PM
hott-rodd
05-03-2008 08:53 AM
Quick Reply: vgt? Non vgt?
