over drive in 66
Old Nov 8, 2007 | 08:46 AM
sgreen's Avatar
sgreen
John, I was outlining the components I am using while trying to make this work. The tranny is from an 88 towncar and the column is from a 79 f150, you're right the "power steering" is irrelevant to this topic. The linkage, is between the column and the tranny used to change the gear. The linkage is binding so I have been considering just putting a standard trans in.
You did answer my question though, thank you.
I may look at the aerostar floor shifter if I can't get the binding cleard up.
Scott
Old Nov 8, 2007 | 11:28 AM
jowilker's Avatar
jowilker
Scott
Ah Ha, Now that you have put more pieces on the table, it is as clear as mud what the problem is. You need the shift rod that goes with the truck column not one for a car. Grab any shift rod for a pickup with C6 or C4 up to 79 and you should be in bidness.
John
Old Nov 8, 2007 | 01:12 PM
sgreen's Avatar
sgreen
thanks John...
Old Nov 8, 2007 | 01:47 PM
1965F100's Avatar
1965F100
The C6/C4 shifter setup all the way down to where the cable attaches should work for an AOD. An AOD would be a great trans.
As for the manual....never seen a TALL STICK T5, might have to stick with the M5
Old Nov 8, 2007 | 01:51 PM
sgreen's Avatar
sgreen
My aod didn't originally use a cable. I was a hard linkage from the towncar column to the tranny.
Old Nov 8, 2007 | 01:59 PM
1965F100's Avatar
1965F100
or that to The ratio of the linkage is what needs to be right and it will work perfect.
don't forget the TV cable though - or bad news.
Old Nov 8, 2007 | 02:14 PM
sgreen's Avatar
sgreen
That's why I was trying to use the one off the towncar. I may just have some angles wrong and causing it to bind.
Old Nov 8, 2007 | 02:22 PM
1965F100's Avatar
1965F100
most column shift Auto's have a linkage that points up, where floor shift (tbird/coug/stang) units point down.
Old Nov 8, 2007 | 02:28 PM
sgreen's Avatar
sgreen
That's the way this one is, pointing up, with park in the forward position, I believe.
Old Nov 8, 2007 | 02:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Yeah, as long as you stay OUT of overdrive in heavy traffic. Heat buildup from the constant shifting from Drive to Overdrive and back to Drive fries the transmission. The Ford warranty claims costs from 1980/83 AOD's alone, equalled all the previous warranty claims costs for all the other automatics combined. The AOD was the most troublesome auto transmission Ford ever made. Even worse than an A4LD, and that's saying something.
Old Nov 8, 2007 | 03:17 PM
1965F100's Avatar
1965F100
yes - 80-85 IMHO the AOD was a hunk of crap basicaly directly related to poor valve body calibrations and poor engineering of many internal parts.
The 1989-1993 AOD's are 400HP tough and pretty reliable due to some more inteligence on the internals and ESPECIALLY the Valve body. The early years really gave the AOD a bad rap, when accualy once you put some TLC into on, they are very damn nice trans.
Considering I build 1000HP capable drag race versions that still have OD, I would say the trans made a complete turn around - BUT STILL the bad reputation follows them around.
Fine for me, more business.
Old Nov 8, 2007 | 03:29 PM
sgreen's Avatar
sgreen
so where does my 88 fall in all this?
Old Nov 8, 2007 | 03:33 PM
  #28
1965F100's Avatar
1965F100
88 was the last year they used the 3/4 accumulator that was notorious for being leaky and binding - leading to OD band failure. A simple VB upgrade is the solution, and for a truck I would consider nothing less than an A overdrive servo for better holding power. I would also suggest shift kit of some kind.
You can read all you can handle at my site where I sell my products and provide tech advice www.clickclickracing.com
Old Nov 8, 2007 | 03:42 PM
  #29
sgreen's Avatar
sgreen
now you got me wondering if I should just cut to the chase and drop a standard in. I did put a shift kit in this, so maybe that will help. When I get it on the road I will take it down and get the tv cable adjusted correctly.
Old Nov 8, 2007 | 03:58 PM
  #30
1965F100's Avatar
1965F100
use the info on my site to adjust the TV cable....you would be supprised at how many mechanics, let alone TRANS shops have no clue what they are doing.
