timing question
Old Nov 7, 2007 | 10:44 AM
diesel79f150's Avatar
diesel79f150
timing question
78 f150 400cid,4 speed was at elevation of 10,000 feet all its life ,moved from colorado to south dakota not sure what the elevation is now ,truck was in storage in colo for 18months put in a battery and it fired right off towed it to south dakota and it will crank all day long but will not fire, i know its getting spark and fuel could the timing be that far off that it wont even try to fire?
if i remember correctly it was timed at 10btdc what should it be for the difference in elevation???thanks billie
Old Nov 7, 2007 | 11:08 AM
smoke n tires's Avatar
smoke n tires
usually they will pop or backfire when the timing is off. i guess its possible but i would start by setting it at specs even though the elevation is different. check fuel at the carb just to make sure
Old Nov 7, 2007 | 11:15 AM
diesel79f150
i checked for fuel can see it squirt from the venturies when you push the pedal so i know its getting fuel , and i would have thought it would try to pop or backfire aswell but it just cranks, doesnt even act like it wants to fire
Old Nov 7, 2007 | 12:37 PM
Mil1ion's Avatar
Mil1ion
Listed Engine specs are for Sea level.
from High altitude to sea level You always have to retard the timing the closer you get.
My truck goes like "Greased snot out of a gun barrel".... burning 97 Octane .......at sea level.
The air is heavier at SL
Calgary Alberta 3300 ft ASL
Van BC - Sea Level
Retard the timing a bump the more altitude you lose.
Old Nov 7, 2007 | 01:06 PM
blue68f100's Avatar
blue68f100
Remove the distributer cam and make sure the rotor is turning. Also look for corrosion and carbon tracking inside the cap. Every time mine setup for long periods of time I have to clean the cap up.
When you remove the coil wire does it spark while cranking?
Mbrgr1
Mar 25, 2012 11:45 PM
RAGaz
Modular V10 (6.8l)
Jul 13, 2010 10:48 AM
cowboywanabe
South Dakota Chapter
Sep 27, 2009 01:57 PM
watz
2004 - 2008 F150
29
Jun 28, 2006 11:12 PM
mcfardend
Nov 3, 2001 03:20 AM
