HELP installing 00m12
Old Nov 6, 2007 | 09:56 PM
rs50fox's Avatar
rs50fox
I was installing the 00m12 kit and I got as far as the Oil jacket screw. Well it stripped! EZ outs are not doing the trick. Any suggestions?
Thanks
Brian
Old Nov 7, 2007 | 03:15 PM
rs50fox's Avatar
rs50fox
I got the screw out! NOW it runs like **** and makes a bad clanking sound and idles rough.
Old Nov 7, 2007 | 10:21 PM
rs50fox's Avatar
rs50fox
No one has a clue of what this could be? and hints atleast?
Old Nov 8, 2007 | 01:11 AM
geo455's Avatar
geo455
Just to be clear you installed the updated tensioner as well as the oil restrictor? If it's still making noise maybe the chain guide (cassette) broke.
Old Nov 8, 2007 | 12:41 PM
rs50fox's Avatar
rs50fox
Yes I replaced with the updated kit and oil restrictor. I got it to back togather to find it doesnt run rite as it seems to be missing and knocking. Any clues for me?
thanks again
Old Nov 8, 2007 | 03:21 PM
geo455's Avatar
geo455
Go back and check all vacum hose and electrical connections. Is the check engine light on?
Old Nov 8, 2007 | 04:17 PM
rs50fox's Avatar
rs50fox
I havent had to running long but hasnt came on in that time? Do you think the egr valve going to the itake manifold or manifold not being tight got cause it ot knock?
Old Nov 8, 2007 | 05:30 PM
geo455's Avatar
geo455
I know that the egr inlet tube can be a bear when you reinstall the upper intake. Make sure that it's fully seated and the intake itself is not cracked or else that could be a problem. Other than that I am not sure. Anyone else have some ideas?
Old Nov 8, 2007 | 07:48 PM
rs50fox's Avatar
rs50fox
thanks I think thats the problem so ima check in the morning and let you know. I have to get new upper manifold bolts.
GrifN
28
Oct 23, 2017 11:06 AM
thousand_mile_stare
2004 - 2008 F150
21
Nov 13, 2015 12:43 AM
Toytime
Nov 27, 2011 09:26 PM
hotfalcoon
19
May 15, 2011 07:30 AM
ITFD
13
Oct 17, 2005 04:22 PM
