Trans Fluid Leak...
Old Nov 6, 2007 | 06:39 PM
ReadOrDie_DW's Avatar
ReadOrDie_DW
Trans Fluid Leak...
So, heres another question for my AOD on my '94 5.0, the fluid seems to becoming out from behind my converter, the converter isn't cracked, and I can't see whats leaking. I believe its the front pump seal or shaft seal, but I could be wrong. Any comments?
Old Nov 6, 2007 | 07:51 PM
JLDickmon's Avatar
JLDickmon
front pump seal more than likely
Old Nov 6, 2007 | 08:40 PM
ReadOrDie_DW
Thanks JL, btw, I bought both the front pump seal and the shaft seal since they were both under $22, installing them tomorrow
Old Nov 7, 2007 | 09:10 AM
aj197816134's Avatar
aj197816134
E4OD or AOD? I have had this happen to several units. I have found that overheating caused that issue. I installed an aux trans coooler and this really helped. I am not sure if its the same problem but cheap insurance to install a large trans cooler. On one truck I completely bypassed the rad trans cooler and used just the biggest gvw I could get. Just my 2 ccents.
Old Nov 7, 2007 | 10:28 AM
ReadOrDie_DW
Its an E4OD, and I wasn't overheating, I imagine it as the fact that I have bad tranny fluid and I was shoving my fifth-wheel around in 4WD, I just bought this truck so I am stillworking out the kinks in it.
Old Nov 7, 2007 | 11:57 AM
Skandocious's Avatar
Skandocious
...Lol, that would be a very good way to overheat the tranny.
Old Nov 7, 2007 | 12:05 PM
aj197816134
"shoving" the fifth wheel, with bad fluid would overheat the trans and might now show up on the coolant gauge. Just stating that when these transmissions heat up they do the same thing. Hope this all helps
