a/c problem
Old Nov 6, 2007 | 03:37 PM
bansheeduner's Avatar
bansheeduner
Exclamation a/c problem
My a/c has a short in it it decides when it wants to blow cold and when it doesnt its charged i checked everything but the a/c clutch will not get power to work i replaced the switch on the inside and when i would wiggle a purple wire it would work again but would lose power when i hit a bump any wiring ideas to look for? everything else on the a/c system works i just have a short in my wires any help?
Old Nov 8, 2007 | 03:24 PM
bansheeduner
thanks guys no help???????
Old Nov 8, 2007 | 03:45 PM
danr1's Avatar
danr1
"i would wiggle a purple wire it would work again but would lose power when i hit a bump any wiring ideas to look for?"
Did you follow that purple wire both ways and look for a bad connection?
Old Nov 9, 2007 | 10:53 AM
bansheeduner
it goes way back under the dash
Old Nov 9, 2007 | 02:50 PM
airmetdave's Avatar
airmetdave
That's the fun part about diagnostics...
Old Nov 9, 2007 | 03:14 PM
danr1's Avatar
danr1
If you shake that wire and get a response/reaction it has to be that wire or one that moves with it, could be a loose a connector it goes into or one near it that moves when you shake it.
You're going to have to follow it regardless of where it goes until you find the problem.
Old Nov 9, 2007 | 03:28 PM
bansheeduner
thats what i was scared of hahaha
Old Nov 9, 2007 | 03:35 PM
danr1's Avatar
danr1
Well ya can pay someone to do it for ya but chasing down shorts/loose connection "by the hour" can be costly!
