Sponsored by: Innova
AVIC D3 Installation in Ford Excursion
Old Nov 6, 2007 | 03:15 PM
excursioner's Avatar
excursioner
4wd Low
Hi folks,
I have a 2002 X with a factory CD6 changer and rear seat entertainment center (RSE) and I want to install a Pioneer AVIC D3 and still maintain the current features that control the RSE and speed volume control, etc. Has anyone done the install in their superduty or X?
Thanks,
Rick
Old Nov 6, 2007 | 07:05 PM
Toyman's Avatar
Toyman
Why not leave the factory set up alone and put in a window mount GPS. I have the AVIC-S1 it's a great portable unit. You could switch to a different vehicle if needed also. Just an option, the other sounds like a wiring nightmare.
Good luck and let us know if you get it installed and working.
Toyman
Old Nov 8, 2007 | 06:30 PM
CLVNGR's Avatar
CLVNGR
I installed the D-3 in my truck, but I don't have an RSE. If anything check out www.avic411.com. They're helpful, and many of the guys on there are installers and would probably be able to answer your questions. I'll worn you though...sometimes they seem rude, but I'm sure they can answer your questions...hopefully. Good luck.
Old Nov 8, 2007 | 07:47 PM
FTE Trigger's Avatar
FTE Trigger
Originally Posted by excursioner
Hi folks,
Thanks,
Rick
There are interfaces that can tie "most" functions of the radio to the steering wheel control buttons and there are ones that can cater to the RSE. I have to warn ya that some of can be a nightmare to keep up with (wiring). If you're willing to try this yourself, I'd be glad to help you find/pull part numbers and models of various interface kits....finding vendors will be up to you tho... (unless the local FTE sponsor can help )
I do remember a user asking some questions on his steering wheel radio buttons and his new H/U install a few months back- it also happen to be a SD iirc. I'll see what a search turns up...
Old Nov 9, 2007 | 07:33 AM
excursioner
4wd Low
Thanks for the reply guys. My X doesn't have the wheel radio controls and I can do wiring pretty good. I hope you guys can help me navigate the AVIC install. I'm probably not the only one out there planning on doing this. Thanks again for your help.
Rick
Old Nov 9, 2007 | 04:46 PM
Beerstalker's Avatar
Beerstalker
Speed sensitive volume is a function of the radio itself, not of the vehicle, and I don't think the AVIC-D3 has it. Truthfully I don't know of very many aftermarket radios that do.
As far as the rear seat controls get a PAC SWI-PS module. Here are the installation instructions to get it to work with your rear seat controls.
http://www.pac-audio.com/swixprogram...ehicles&ID=369
Was there anything else you needed help with?
Old Nov 14, 2007 | 07:14 AM
excursioner
4wd Low
Thanks Beerstalker, but since my vehicle doesn't have steering wheel radio controls what would the module do for me? Oops, I just checked the pac website and I guess the module would allow me to wire the current harness of the RSE to the avic d3. Am I right? What dashboard kit would i have to purchase to have the d3 fit in the current opening as the CD6 radio in my truck?
Thanks again.
Rick
Old Nov 14, 2007 | 12:59 PM
Beerstalker
Yes the PAC website mentions that it works with the rear seat controls as well.
For the dash kit get a Metra 99-5805 or Scosche FD1330B.
bobv60
Oct 21, 2015 06:13 PM
Evan Stoll
Sep 8, 2015 05:28 PM
powerkmac
Apr 25, 2014 07:48 PM
bkks744
Mar 13, 2008 12:12 PM
Kiki's Ring
Oct 7, 2007 11:46 AM
