Chimes unplugged
Old Nov 6, 2007 | 03:00 PM
kawa's Avatar
kawa
Chimes unplugged
Found it, felt it and listened to it then unplugged it. That noisy little SOB has an awful lot of wires plugged into it and that has me wondering does it disconnect anything else except what dings on my OBS, Ign & head lights?
Is there something else that dings that I don;t know about and possibly not working? Should i be worried?
Anything will help to give peace of mind.
Rog
Old Nov 6, 2007 | 04:19 PM
jboard's Avatar
jboard
Not that I know of it should be fine, lots of people do it.
--------------Jeremy
Old Nov 6, 2007 | 05:15 PM
plowhand's Avatar
plowhand
Playing in the Dirt
The wires are for: key in ignition, head lights on key out of ignition and who knows what else.
Old Nov 6, 2007 | 05:55 PM
Action4478's Avatar
Action4478
You may be able to fill it with hot glue & plug it back in
I've done that in the past...Not sure if it will work for you..
(disclaimer)
Old Nov 6, 2007 | 06:08 PM
StrokeThis96's Avatar
StrokeThis96
one of the first things i did to my PSD when i got it was unplugged that SOB. havnt had any trouble since then so u should be fine
Old Nov 6, 2007 | 06:21 PM
kawa's Avatar
kawa
I bow to the Lords of knowledge, the SOB is silent and I'm
happier than a Ho on payday night with a credit card machine.
Thank you again.
Rog
Old Nov 7, 2007 | 02:41 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
And with it unplugged, what happens if you forgive to turn off the lights? does it have a different chime?
Old Nov 7, 2007 | 02:43 PM
StrokeThis96
well, ur gonna hafta look for someone with some jumper cables. no other chime, once chimer is unplugged u wont have to deal with the dang sound anymore
Old Nov 7, 2007 | 02:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
OK, I suppose that but why not use a switch to bypass it when not needed?.
Old Nov 7, 2007 | 02:56 PM
ForemanES's Avatar
ForemanES
I noticed with mine unplugged my emergency flashers didnt work (and I just so happened to need then at the time). Plugged it back in and they work fine.
Old Nov 7, 2007 | 05:54 PM
plowhand's Avatar
plowhand
Playing in the Dirt
FYI you can just unplug (at the chime box) the wire that goes to ignition switch, This way it will not chime with the key in, but it will chime every time you open the door with the lights on because it can no longer tell if the key is in or out. Just my $.02
Old Nov 9, 2007 | 07:54 PM
kawa's Avatar
kawa
I like your $.02 but...... how do you know which wire goes to the ignition switch? Do you have a photo, the color or location on the ding a ling box???
Thanks for your input.
Rog
Old Nov 9, 2007 | 08:27 PM
c00nhunterjoe's Avatar
c00nhunterjoe
Old Nov 9, 2007 | 09:17 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
well thats the connector but what is the specific wire that Plo said that goes to ignition switch?
Old Nov 9, 2007 | 09:18 PM
c00nhunterjoe
the thick black one that is circled in yellow and is disconnected in the picture
