Sticking brakes
Old Nov 6, 2007 | 01:42 PM
mgraveman's Avatar
mgraveman
Sticking brakes
I just got my 77 running (needed a new carb) and my brake pedal is sticking down. It feels solid, like it's bled properly, but it just doesn't come back up. What is supposed to make these come back up nomally?
Old Nov 6, 2007 | 01:48 PM
ErrorS's Avatar
ErrorS
err, i read it wrong, nevermind.
Old Nov 6, 2007 | 01:55 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Might be a bad brake booster. Either that or you forgot to hook up the booster vacuum line?
Old Nov 6, 2007 | 02:02 PM
ErrorS's Avatar
ErrorS
is there a return spring in these trucks or is it all handled by vacuum? I wasn't sure at first...
when my booster went out, my brakes were to the floor. They returned fine, it just didnt stop very well.
Old Nov 6, 2007 | 02:46 PM
mgraveman's Avatar
mgraveman
I didn't look, but the booster line didn't go to the carb. The only big line going to the carb was the PCV. I had a vehicle with manual brakes and it worked fine. Also, I've never seen a vehicle that is shut off have brakes that stay down.
Old Nov 6, 2007 | 03:03 PM
ErrorS's Avatar
ErrorS
the booster line goes straight to manifold vacuum, should be a T at the back of the intake.. big hose, about the size of a fuel line.
I don't think that's what it is though.. but I do think there is some kind of return spring either behind, or inside of the booster. Might want to take it off and check it out if noone else who knows for sure responds anytime soon.
Old Nov 6, 2007 | 04:30 PM
mgraveman's Avatar
mgraveman
I was wondering if there was one in the master cylinder. I've never been inside one of those.
Old Nov 6, 2007 | 04:33 PM
Mil1ion's Avatar
Mil1ion
No return spring.
what makes the pedfal come back ?
Hydraulic's .
The brake fluid in the WC's is withdrawn and sent back to the MC by the rear brake shoe return springs.
The front pads are just barely relieved from the rotor when the pedal is relieved.
what causes no pedal return ?
Bad M/C
Bad BPPV
Bad Rear brake return springs.
Check your push rod adjustment
Old Nov 7, 2007 | 07:33 PM
rusty7983's Avatar
rusty7983
well i disagree. i had my old ranger's booster fill with brake fluid. now i said fill, with fluid, approx. 8 ounces. it would hole the brakes to the floor. the fluid i dumped out was rusty and i eventually replaced the master, as it leaked alot. i used to frequently refill it.
