6.9 efficency
Old Nov 15, 2007 | 10:13 PM
David85's Avatar
David85
Originally Posted by 87crewdually
My last consistant driving in my 87, 6.9, dwcc, c-6, 4.10 R&P truck doing 50-55mph @ 25-2700rpm with 6 cetane boost via Diesel Kleen I got 16.5 mpg. Over drive or 3.55 r&p would help alot more. I don't think thats to bad for a 5000lbs+ truck.
16 MPG with a 4.10/C6 combo is very good, just make sure its not an anomalous reading from the fuel shutoff kicking out too soon, I got a 32 MPG reading once (fuel gauge donsn't read accurate, so it looked like it was full). But I think 16 MPG is doable if you consistently cruise at 55 MPH or slightly less. Changing the gears will help bring your optimum cruise speed up slightly, but considereing you are driving the biggest truck possible in that body style, I'd say you are doing well the way it is.
Old Nov 16, 2007 | 08:16 AM
lowell75's Avatar
lowell75
87' E350 6.9 C6 3.31 Srw
The local who does driveline work said he'd install a
3.07 for me for about $300 (used one). It was obvious
doing the calculations and checking mph with a GPS a
3.31 was what was installed.. From 3.55 to 3.31 was
an improvement and a pair of new 33 inch diameter
tirees pretty much got me to where I will stay for awhile.
If I were go to a E40D would a different converter
be needed ? diffferent length driveshaft? other?
Lowell75 thanks.
Old Nov 16, 2007 | 11:11 AM
David85's Avatar
David85
Lowell75 thanks.
If you go to an E4OD, then you will need a different torque converter, shorter driveshaft, wiring harness and computer, and modify the crossmember. Its possible to use the flexplate from the C6, but I would not recoment it, so you should get a flywheel/flexplate from a 7.3 IDI that originally had an E4 behind it.
And if you ever want to build up the engine for more power, now is the time to build up the tranny to survive it.
Old Nov 16, 2007 | 05:03 PM
87crewdually's Avatar
87crewdually
I take no chance with faulty readings from not filling up all the way. Every fill-up I pump it slow at the end til it's in the filler neck for accuracy and longest range.
Old Nov 16, 2007 | 05:11 PM
deerhead's Avatar
deerhead
Could some one tell me how to post a new thread.I have a problem and you people have helped me in the past but iam a computer IDIOT.
Old Nov 16, 2007 | 07:02 PM
starmilt's Avatar
starmilt
deerhead lefthand side top of forum button for new topic.
Old Nov 16, 2007 | 07:44 PM
deerhead's Avatar
deerhead
thank you for your help
Old Nov 20, 2007 | 04:37 AM
xoddah's Avatar
xoddah
Red face The Giant is awake
[QUOTE=xoddah]I just bought a 83 / 84 / 85 ? e-350 cube van 6.9 not run in 3 years
i am - was a cat, cummins, DD diesel tech for a lot of years and have the skills and "some" basic knowledge of automotive diesel with your advise-s posted I'll get'er going my question is with a c-6 transmission what are my options for a "highway" geared differential ...ratios available, and or, possible interchanges with u-pull it wrecking yards ie: will a f-350 diff drop in work in my e-350
this is an additional work van, 400 miles trips don't want the tach pegged all the way there
but for 400$ + make it run costs it is worth a try
WELL I got'er going in about 2 hours absolutely runs like a clock 1986 model almost new .even has tiger stripe seat covers . a couple of safety issues ( flush brake system) clean out fuel tanks, add a Fuel/Water separator, belts, hoses, fluids, shine it up a little then up and over Mt. Hood for a test ... I live at the bottom so i can roll back home if i have a problem
THEN on to the gear swap
thank you for the great advice
