Flywheel ID????
Old Nov 5, 2007 | 09:10 PM
rollinclassic's Avatar
rollinclassic
Flywheel ID????
Anyone know how to ID a flywheel and tell if its the right one for a 460 77-79 era? I know there is a 180 & 184 tooth, does anyone know which one goes to which? how to tell besides counting all the teeth? Any help is appreciated!
Old Nov 5, 2007 | 10:14 PM
Mil1ion's Avatar
Mil1ion
Flywheel or flexplate ?
No 460 trucks had M/T's
Old Nov 5, 2007 | 11:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1979 460 engines used two different A/T flexplates.
You need to know which block you have, so look for a casting number of either D1VE-6015-AB or D9TE-6015-AB.
The D1VE casting numbered engine uses: D1SZ-6375-A .. Flexplate
The D9TE casting numbered engine uses: D9TZ-6375-A .. Flexplate
Sorry, the parts catalog doesn't give the tooth count.
Old Nov 7, 2007 | 10:50 PM
rollinclassic
Flywheel right?
Ok, this truck did originally come with a 351 but had a rebuilt 460 put in it. So that's why it has a manual trans.
Old Nov 7, 2007 | 10:52 PM
rollinclassic
It doesnt have an A/T, the engine in it now did not come in the truck originally. It was put in after the 351 blew on the previous owner and he had the 460 put in. The starter teeth aren't connecting with the flywheel teeth and grinding and then just not even connecting making a horrible grinding noise.... trying to figure it out.
Old Nov 8, 2007 | 04:33 PM
Mil1ion's Avatar
Mil1ion
Now we know .
The "flywheel vs flexplate" mistake is made all the time... we had to ask to verify.
You get the flywheel for a 84 460 M/T. 180 teeth IIRC
check the number here.
http://www.rockauto.com/catalog/x,ca...,parttype,5348
Old Nov 8, 2007 | 08:29 PM
rollinclassic
thank you guys for all your help. We diving into it more this weekend!!
Thanks again
Old Nov 8, 2007 | 09:33 PM
79-400-POWER's Avatar
79-400-POWER
[QUOTE=Mil1ion]Now we know .
http://www.rockauto.com/catalog/x,carcode,1123816,parttype,5348[/QUOTE]
while we are asking and verifying, you do kno w 84 460 flywheel wont work on a pre 79 460?
he needs a 390 flywheel
Old Nov 18, 2007 | 04:50 PM
rollinclassic
[QUOTE=79-400-POWER]
Now we know .
I'm not sure I understand your last part of your response... are you asing if I know why the 84 460 flywheel wont wor on a pre 79 460? Maybe you should not ask me that, but ask the nice person who gave me some more info to try about getting the right flywheel.
You say I need a 390 flyhweel. Where is your back up info as to why I should pursue a 390 flywheel? what do you have information wise, for me to believe you any more so than any other guy?
Thanks for the time
Old Nov 18, 2007 | 05:10 PM
79-400-POWER
pre 79 460s were internally balanced, so they use flywheel/flexplate that is neutral balance where as 79 and up were externally balanced, so they need a flywheel/ flexplate that has a weight in them to set them to the correct balance for the motor. but since flywheel for a pre 79 460 are few and far between, and 390 flywheels plentiful and are of neutral balance they work just as well. i have 360 flywheel on the 73 460 that i just put in my 78 bronco. the 360 will work too but it is for a 11" clutch where as the 390 is for the 12 "clutch
Old Nov 18, 2007 | 05:33 PM
Mil1ion's Avatar
Mil1ion
More info on the 460 with an M/T can be found in the 385 engine series forum and the engine swaps forum
Old Dec 5, 2007 | 11:05 PM
jstephenson's Avatar
jstephenson
there was a place that made a flywheel brand new for the internal bal 460 i bought one. One thing I did notice that the ring gear is a little wider than the standard ring gear, because as i was told the crank sits in slightly differant distance from the block. If you haven't found one yet let me know and i will dig out my receipt and get the info for you
Old Dec 26, 2007 | 08:25 PM
orich's Avatar
orich
After 1862, I think was when ford changed the 390 12" clutch flywheels, Whiched to the 184 tooth 11.1/2" F/Wheels and changed the starters also. Today most flywheels our drilled for either the 360 0r 390 clutch setup... my 2 cents
orich
