2001 explorer steering vibration problem
Old Nov 5, 2007 | 09:39 AM
96expblk's Avatar
96expblk
replaced ps pump about 5 months ago. Reved engine to 2500 rpm and turned wheel lock to lock. It reduced vibration but vibration came back shortly and now it vibrates just as bad as before replacing the pump. I thought air would eventually work out of system but it hasn't happened. It is not a 4 wheel drive. Do you think trying the vacuum pump process would get the air out if getting air out is the problem I'm having. Could I possibly have rack and pinion problem instead of air in system?
F7 Firecat
Jan 13, 2020 01:48 PM
jimlj
May 26, 2017 01:42 PM
polarisman
May 28, 2015 12:27 PM
sherbrookejeff
Dec 20, 2013 07:06 PM
bluebaker
2004 - 2008 F150
27
Feb 27, 2006 04:17 PM
