Hello, I am looking to beef up my truck with a stronger rear axle. I am doing a cummins swap into a 95 f-150. I have beefed up the front end, but the rear is still lacking. I do not, under no circumstances, want to go to an 8 bolt option. The front has 5 lugs and I have allready purchased new 5 lug rims and tires.
I have a spare 9 inch rear axle laying around, but it dosen't have an abs exciter ring or sensor on it. A buddy mentioned a way to put it on and said that he saw it online. I have been looking everywhere and have found nothing.
I was wondering if a 9.75 axle would do the trick. I am not sure what f-series truck they came on, I'm assuming 97-up f-150's ? Anyone know?
I don't think there is any way to get the exciter ring off an 8.8 on to a 9" so you will be without a speedometer and odometer unless you put aftermarket ones. I also think it would be hard to get the sensor in the 9" too, you might be abel to stick it out the back of the housing some how but I think the exciter is the big problem. I would just go with an aftermarket speedo and ditch the abs. The VSS is also need for the computer controlled automatic but I don't think that is an issue with the cummins swap the only real issue is the speedo unless you just really have to keep the abs. just my $.02
To do that with a 9in you need to have a tone ring cut and have it mounted somewhere on the driveshaft flange. Most that I see are milled to go where a companion flange would bolt to either at the diff or the t-case. If you want to use a sterling 9.75 you are right, 97 and up F-150s, same size ring gear as a Dana 60 so it's pretty stong.
I saw that article, too, but neither saved, nor bookmarked it. I do know that I got there via links from some Bronco sites.
In any case, as far as I can remember, they did a bit of machining on a lathe, then heat up the exciter ring to cherry red, and then pressed it on. Then they drilled and tapped a hole for the sensor.
