motor size
Old Nov 4, 2007 | 08:18 PM
lgower's Avatar
lgower
motor size
looking to buy a new truck,new to me, around a 93 to 96, whats better 4.9 , 5.0 , 5.8 . daily driver, but will pull my airboat, no real weight just wind drag, thanks, for the help, Lee
Old Nov 4, 2007 | 08:20 PM
nickh's Avatar
nickh
All would pull an airboat get the 5.8 if you dont mind giving your paychecks to the gas station
Old Nov 4, 2007 | 08:26 PM
17fordguy's Avatar
17fordguy
if you lookin to pull and and not to speed go with the 300 4.9
Old Nov 4, 2007 | 08:30 PM
khadma's Avatar
khadma
Carpenter Local 745
4.9 or 5.8 - Both tough engines, your choice.
Old Nov 4, 2007 | 08:31 PM
lgower's Avatar
lgower
motor
what about running the inerstate around 70mph
Old Nov 4, 2007 | 08:48 PM
nickh's Avatar
nickh
Dont be so needy.
I'm no expert but i think that would depend on the gears.
Old Nov 4, 2007 | 08:50 PM
khadma's Avatar
khadma
Carpenter Local 745
That job would go to a Harley-Davidson Fatboy with a TC96B!
My 5.8 moves along pretty good at that speed, but 60 is the legal speed limit here.
ford_boy_1996's Avatar
ford_boy_1996
I would go with the 4.9 or a 5.8 it also depends on the gears in your diffs and std or auto. I like 3.55s with a good 5 speed or E4OD they are good all around set up.
Old Nov 4, 2007 | 09:00 PM
frederic's Avatar
frederic
You'll find that most of the F-series engines seem to get in the 10-14 mpg range in an unloaded/unhitched truck depending on the gearting, even the 460. We've had many threads pass through here with people quoting all sorts of mpg figures and what it really comes down to is how hard you use the throttle.
For a given weight/wind resistance/gear ratio you can calculate out how much HP is necessary to accelerate. The 460 will produce this power at a lower RPM range than the other engines, the 302 requires a bit more revving but the displacement is smaller, and the 351W is a balance of the two actually - reasonable displacement and the power mostly down low.
The I300 doesn't make for a "quick" truck but it's by far the most reliable and it hums along essentially forever if you take care of it. It's a big bore six cylinder so it's fairly torquey. Just not quick off the line as compared to the other engines.
My F350 crewcab has a 351W, and I do believe it's the engine for those who drive unloaded a little more often than they tow. It's a reasonable balance.
