Rear end gear swap. What about the front end?
Hi Guys;
I searched around to make sure this hasen't been asked before without success. I am in the oricess of swapping up my rear end ratio from 3:55 to 3:80's to accomodate a lift and tires. This may seem like an odd question, but would I not need to up the Dana 44 ratio on the front end as well. If someone can shed some light on this I would appriciate it.
Thanks.
Thanks.
YES. You need to keep both ratios within 1% of each other, otherwise you'll tear up the drivetrain (probably the transfer case will go first).
The one exception to this is if you ONLY drive it on sloppy surfaces. I hear swamp racers run different ratios. Any contact with a high-traction surface when you have different ratios will start causing damage.
Jason
Jason
What size tires are you going to run??
Originally Posted by hovey30
Hi Guys;
Thanks.
Thanks.
mchbts
04-07-2012 11:17 AM
uzzaw
08-20-2005 12:22 AM
RangerTuff05
08-03-2005 06:45 PM
Rancho*Ryda
06-02-2005 01:46 AM
