I went offroading once and it fixed a blown tail light/turn signal.. didn't realize until I came home that it.. 'unfixed'.. all (but one) of my dash lights.
not taken off the dash to check why or to fix them, so I guess this post really didn't add much to help you, sorry.
I'm having a similar problem as well... thing is I've found the bad bulbs, I just can't find them at a store to replace them. Anyone know of a place online perhaps?
Well i checked the fuse again, glad I actually used a meter this time because it was bad. I replaced it with a 10 amp that I had, turned on the dash lights and it blew instantly. I relaced the headlight switch, tried it again and it also popped. I disconnected the dash from the wiring harness, same thing. Any suggestions?
i had this prob for the longest time! i just broke down and bought a headlight switch. did not solve the prob. it ended up being the headlight switch pigtail. i got that soldered in and everything works top notch now!
headlight switch-around 20 bucks
pigtail- 14ish
hope this helps
Mitch
Oh ok, well that will give me somewhere to start looking then. come to think of it I did see that someone had butchered some wires back behind the radio. I didn't think any thing of it and put it on my "someday I'll fix that too" list. (that was probably 2 yrs ago)
It could be as simple as the blue/red wire touching ground.......but usually turns out to be some did it on purpose because they didn't know what they were doing
Yep, your right Mil1ion, previous owner some how had the radio ground hooked to that blue/red wire. I guess that was supposed to go to the ashtray light.?(Which is missing) Now for your next quiz...... Gas gauge inop. test light at the quick connect in the rear at the tank shows a pulsating light. Is that normal? Keep in mind, I am using the same ground for the test light as the sending unit.(in other words I believe the ground in OK.)
Thanks again Mil1ion, I dropped the tank today. The sending unit full of fuel. I am trying to locate just the float but can not find anything. Autozone, Advanced Auto, And Oriley's just want to sell the whole kit and kabootle for $65. Any idears
