4 speed toploader questions
Old Nov 4, 2007 | 06:24 PM
royalchoppers's Avatar
royalchoppers
I am strongly considering replacing the auto tranny in my '65 with a 4 speed top loader. My questions is, if I can only find one that is non-overdrive, can I switch out the 4th gear to an overdrive gear. Or will the jump from 3rd to 4th be too great? I would really like to have an overdrive gear, but I am trying to do it fairly budget. Any help would be appreciated.
Old Nov 4, 2007 | 06:55 PM
baddad457's Avatar
baddad457
You cannot swap gearsets between the 3+1 Toploader and the older close or wide ratio Toploaders. The main cases are different between the two. If you want overdrive, buy a 3+1 OD Toploader to start with.
Old Nov 4, 2007 | 08:29 PM
royalchoppers
Thanks, that was what I was worried about. They are proud of the 3+1OD toploaders.
Old Nov 5, 2007 | 05:01 AM
baddad457's Avatar
baddad457
The earlier 4 speed Toploaders sell or even more. If you have a small block, I'd look at the 80's version, the all aluminum top shifted one, or step up to an M5OD-R2 5 speed that was used behind the 300-302-351's in the late 80's to mid 90's.
Old Nov 5, 2007 | 09:18 AM
royalchoppers
I have a FE 352, so that won't work. I found a nice adapter kit to convert the FE to any Ford SB Tranny, but it is $750, ouch!
Old Nov 5, 2007 | 11:47 AM
62_Galaxie_500's Avatar
62_Galaxie_500
There's always the TKO-500/600 route, but at about $2000 it is probably out of your budget, right?
Old Nov 5, 2007 | 12:16 PM
royalchoppers
Yeah, that is a bit high for me right now. I am emailing with Mike at Fortes right now, and that is the setup he sells. I can dream I guess. Looks like the Cruise O Matic will remain for a while.
Old Nov 5, 2007 | 04:33 PM
baddad457's Avatar
baddad457
The Aluminum Toploader from the early 80's pickups will bolt up top a Toploader bell, you might need a 1" spacer though for the longer input shaft, or possibly thinner if you've got a C5TE bell for your 352. And then there's the SROD used in the Stangs too, sure they're not as tough as the iron cased ones, but if you don't abuse it, it ought to hold up fine.
Old Nov 5, 2007 | 06:39 PM
73F100*8Mile's Avatar
73F100*8Mile
See thats my prob, I wanna go stick too but the T5's won't hold up to 418ft lbs! I'd like to go w/ the chiivy AOD but that adap is upwards of $750 I think and then gettin the J/Y AOD rebuilt won't be that cheap either.
Old Nov 10, 2007 | 01:03 PM
mattri's Avatar
mattri
Been looking at this myself with the 69. So far it doesn't look like there is an economical way to get an od behind an fe. Glad for the post though, the more we kick this around the more likely we are to find something.
62 Galaxie is right, the tko's are awesome but 2k is steep.
Old Nov 10, 2007 | 01:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's another choice if you can find one. 1965/72 F100's could be ordered with the Warner T-85N 3 speed overdrive. With the right rear end ratio, 20+MPG can be obtained on the hwy. City mileage will be about the same, however. The present steering column remains the same. The trans was also used in 352: 1958/67 Galaxies and 1958/60 T-Birds.
The Ford 4 speed TSOD is a weak sister, and can barely stand up to a 300, 302 or 351W without breaking. The shifter mechanism is a POS, with a little plastic bushing that snaps off. On some shifters, it can only be bought with the entire assembly. First introduced in 300 I-6 and 351W 1975 Econolines, and used thru the 1980's.
Old Nov 10, 2007 | 05:12 PM
Dave Severson's Avatar
Dave Severson
Guess I don't know of a cheap way to do it. The TKO 600's are one tough tranny!!! They are rated for up to 600 ft. lbs of torque. The other option to get over drive is a Gear Vendors unit, but they run about $2400.00 too.
Old Nov 11, 2007 | 08:04 PM
just-n-time's Avatar
just-n-time
I don't know ware you live but at the auto U pull it centers you can buy a five speed for 358 bucks.
Old Nov 15, 2007 | 02:43 PM
mattri's Avatar
mattri
A five speed yes, one that will bolt up to an fe, no.
Old Nov 16, 2007 | 06:07 AM
norvillebob's Avatar
norvillebob
I have a TOD from a 87 f250. It bolted right up to a truck bell no real issues. You will have to get a 24 spline yoke and driveshaft work.
The 3 speed is real nice with my 390. I thought I would not have enough gears but it's not a problem. And in 4th I run down the highway at 70+ @/2400 rpms I have 4:10's
I paid $25 for the tranny I thisn it's also known as a 170 rts. 3+OD
I don't beat on it my 250 is a DD Check the bronco forums or J-yards. Not many folks seem to like them, but it's a bolt in solution. If I had a 9" rear I may have just went with higher gears.
bob
DarylZ
16
Nov 26, 2007 08:19 PM
jarmbrester
Oct 13, 2003 08:55 PM
bkaeding
All Things Towing
Jul 2, 2003 02:32 AM
idealtrucks
Jun 18, 2003 10:46 AM
