Automatic overdrive tranny install
Old Sep 6, 2002 | 06:43 PM
AKFord's Avatar
AKFord
Has anyone ever installed one of the early auto/overdrive trannys behind a 73-79 that originally had a 4 spd? I know I would need to get all of the linkage, mounts, transfer case, etc... but I just wonder if they will bolt to a 300 crank that was originally set up for a manual tranny. Thanks!
Old Sep 10, 2002 | 12:15 PM
54_5star's Avatar
54_5star
Old Sep 10, 2002 | 10:04 PM
MSTRAWN's Avatar
MSTRAWN
Get the flex plate and seperator plate from any AOD application. Any later model I-6 with an AOD can be a doner. The linkage is the tricky part. You absolutely must be able to set the TV pressure to specs or you will fry the transmission is very short order. I put an AOD in my 77 about 6 months ago. One thing to check is the rear end gear ratio. Anything less than a 3.0:1 will lug the engine in overdrive. I am putting 3.25:1 in mine right now, plus a Detroit Locker. 500CFM Edelbrock with offenhauser intake and Hooker supercomp hearders and MSD ignition were also added.
dadz34
29
May 6, 2014 06:37 PM
Sherbo
May 21, 2011 01:00 AM
ralf
1978 - 1996 Big Bronco
Feb 26, 2007 01:28 PM
plowguy
Jan 6, 2006 06:23 AM
f1004me
Sep 18, 2005 07:40 AM
