Boost/Leak test Help!!!!!!!!!
Old Nov 5, 2007 | 07:34 AM
rbaker6336's Avatar
rbaker6336
Originally Posted by mndiesel
Truck runs fine no stumbles nothing, 16mpg around town, 12-13 towing. EGT,s ok 600 at 70-75mph empty and 700-800 while towing 8k lb TT at 70mph on even ground
with those numbers hard to think anything wrong other than guage reading
Old Nov 5, 2007 | 03:10 PM
mndiesel's Avatar
mndiesel
OK I now did the AIH delete and the boost hose on the wastegate. Still have the same problem. Could this be caused by the wastegate somehow. I am just taking shots in the dark here. When I took the truck for a ride it definately boosted faster but still went to zero when I let off or kept it at a steady speed.
Old Nov 5, 2007 | 06:04 PM
Ford79's Avatar
Ford79
It could be wastegate related, just not sure how. Wastegate opening too soon? I believe that can be adjusted, but wouldn't disconnecting the line tell you the same thing as a bunch of adjustments? I could possibly stop by one of the afternoons to help trouble shoot with you. I'm in Minneapolis every week day for work. I'm by no means a Diesel mechanic, but sometimes two heads are better than one.
greenstar
Apr 2, 2014 06:04 AM
FROGMAN524
23
Mar 2, 2011 10:14 PM
Mr. Andrew
Mar 29, 2010 10:52 PM
shark1979
15
Jan 27, 2010 06:12 PM
rosa70
18
Jun 17, 2004 10:12 PM
