Planetaryg gears
Old Nov 2, 2007 | 09:58 PM
Huntersbo's Avatar
Huntersbo
Planetaryg gears
On modern overdrive automatics is overdrive part of the gear combinations of the planetary gears or is it another componet entirely? I have found that for the 3 speed autos there are different combinations aviable just by changine the planetary gears. The planetary gears move to make different combinations so why can't a C6 have 4 speeds like the 4R100?
Old Nov 3, 2007 | 10:13 AM
stuart1's Avatar
stuart1
You need another set of clutches.
It is called E4OD.
Old Nov 3, 2007 | 08:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Not just another set of clutches, you also need another planetary set. There is an overdrive planetary set in the front of the E4OD/4R100. This set shifts from 1:1 to 0.71:1 to shift from 3rd gear to overdrive.
