Sponsored by: Auxito
2002 F-150 a/c
Old Nov 2, 2007 | 07:12 PM
coachlord's Avatar
coachlord
2002 F-150 a/c
When I turn on the a/c, the compressor kicks on but nothing blows out the vents. What's causing this? There was also a light clicking noise when the a/c or heater is running. One other thing, if the air does decide to blow through the vents, it blows erratically.
Old Nov 2, 2007 | 07:54 PM
steve(ill)'s Avatar
steve(ill)
if the blower is not running, you have a fan problem, if the fan runs, but no air at all, then the coil or heater is plugged... if the air always comes out the defroster, then you have a vacuum leak from the engine to the heater control **** and the default for no vacuum is to blow to the windshield louvers.
