alt. bracket
Old Nov 2, 2007 | 01:57 PM
79-400-POWER's Avatar
79-400-POWER
alt. bracket
when i made the bracket for the ps pump i wasn't thinking about the alt. and wound up making it so the belt comes off the front of the pulley now i am trying to make a bracket for the alt. but if i use the back of the pulley its too close to the block, so i was wandering if i could use the front pulley and it would just have a a longer belt going around the ps pump and the alt?
Old Nov 2, 2007 | 02:13 PM
79-400-POWER
ps. its a gm one wire
Old Nov 2, 2007 | 02:21 PM
monsterbaby's Avatar
monsterbaby
are the crank pulleys the same diameter? if so the alt doesn't care which one it's run off of.
Old Nov 2, 2007 | 02:34 PM
79-400-POWER
they are the same size, but what i was thinking is could I use one belt for the ps pump and the alt. it would goe around the crank pulley then the ps pump, then the water pump, and then the alt. if i got it tight enouf so it wont slip.
Old Nov 2, 2007 | 03:29 PM
monsterbaby
not a good idea, too many things on one V belt won't be able to drive them and not slip most likely
