Air filter change...
Old Nov 2, 2007 | 10:17 AM
MattyNJ's Avatar
MattyNJ
Time to change the AF on my '05 diesel, and I was just wondering if I should just upgrade the Air intake or just replace the stock donalson AF (I beileve), with a new one? Can I buy this stock AF any where else besides a Ford dealer? what should I expect to pay?
Great site by the way, I have the '05 F250 SD Lariat and Iam happy with the truck thus far (32k), although not exactly thrilled with the mileage (12mpg).
Thanks
Matty
Old Nov 2, 2007 | 10:45 AM
Super08's Avatar
Super08
Stay with the stock filter IMHO, been alot of turbos damaged from dust due to aftermarket set ups.
Old Nov 2, 2007 | 10:57 AM
MattyNJ's Avatar
MattyNJ
Thanks, Motorcraft or donalson?
Old Nov 2, 2007 | 12:10 PM
dchamberlain's Avatar
dchamberlain
You can do some online searches and try to find the best price. The best price I've found so far is here.
http://shop.ivalueinternet.com/shopd...duct_id/46.htm
And, if you need to change oil and fuel filters, or if you just want to stock up for next time, you can save a bit more money here.
http://shop.ivalueinternet.com/shopd...ct_id/1095.htm
Old Nov 2, 2007 | 12:33 PM
MattyNJ's Avatar
MattyNJ
Thanks dc, can you get em at any R&S Strauss, or Auto Zone? oh by the way I think there a bit cheaper here http://www.dieselfiltersonline.com/F...n-Fa-1778.aspx
Old Nov 2, 2007 | 12:36 PM
dchamberlain
I'm sure you can get them at most auto parts stores, but I imagine you are going to pay quite a bit more. I haven't needed to change mine yet, so I haven't checked prices locally, just noticed the online prices while I was looking for oil and fuel filters.
Old Nov 2, 2007 | 12:38 PM
MattyNJ's Avatar
MattyNJ
This is my 1st change. Thanks for the info, bookmark that link though its the cheapest ive found so far!
Old Nov 2, 2007 | 12:43 PM
WilliesSD250's Avatar
WilliesSD250
Stay with your stock air filter..........it's far superior to any aftermarket setup. Many folks here have spent hundreds of dollars on aftermarket set-ups only to switch back to stock
Old Nov 2, 2007 | 12:46 PM
MattyNJ's Avatar
MattyNJ
Thanks *******, so replace with a motorcraft AF correct?
Old Nov 2, 2007 | 12:55 PM
WilliesSD250
As long as it's a Donaldson you'll be fine
Old Nov 2, 2007 | 12:57 PM
MattyNJ's Avatar
MattyNJ
Ok now im confused, I thought Donalson was different than Motorcraft? as in 2 diff filter part numbers?
Old Nov 2, 2007 | 01:29 PM
blackhat620's Avatar
blackhat620
The OEM 6.0 filter is a Donaldson Powercore. The part numbers are different only because Motorcraft uses a different numbering system.
There are two styles of this filter however, the "Blue synthetic" media which is water resistant & filters slightly better (Factory installed) and the "White cellulose" media which is not water resistant but is slightly cheaper to purchase. Stick with the Blue synthetic media.
Also the Air filter element only needs to be changed when the "filter minder" indicates it is time. Filter minders have been used on heavy trucks and off road equipment for years. The OEM Donaldson Powercore filter can hold over 3lbs of dirt and can last up to 80k miles. Changing the filter prior to the filter minder indicating it is time is just a waste of your money.
The OEM Donaldson Powercore filter provides the best filtration on the market and flows more air than the 6.0 can use until you exceed 500+RWHP.
Old Nov 2, 2007 | 01:30 PM
Joshua0606's Avatar
Joshua0606
I heard its good as long as the filter is blue. Most parts stores have this kind.
Old Nov 2, 2007 | 01:32 PM
MattyNJ's Avatar
MattyNJ
Where is the filter minder? never have seen this???
I was told its about time for a change from my dealer, Im at 32k?
Old Nov 2, 2007 | 01:47 PM
blackhat620
Filter minder is located on the back of the Air filter housing. Here is what they look like.
www.filterminder.com/
Your local Ford dealer is full of crap. Look in your manual it says change the filter based on the filter minder.
