Bronco II Ford Bronco II
looking at 1990 bronco II
Old Nov 2, 2007 | 10:12 AM
tallpaul14's Avatar
tallpaul14
looking at a 1990 ford bronco II for 700$ two wheel drive, standered transmission, what problems do I need to look for? thanks.
Old Nov 2, 2007 | 10:42 AM
mrshorty's Avatar
mrshorty
Assuming it's stock, it will have a 2.9 L V6. Look for cracked heads (water in oil), leaking valve cover gaskets. 2.9 will sometimes exhibit lifter noise, which may or may not be a real problem.
Which 5 speed tranny: Mitsubishi (FM146) or Mazda (M5OD)? Mitsubishi transmissions have input bearing issues.
Can't think of anything else off the top of my head.
Old Nov 3, 2007 | 12:34 AM
1996pwrstrk's Avatar
1996pwrstrk
Is the 2.9 the one with mechanical lifters ?
Is there any other way to check the trannys or do you just have to crawl under and compare #s
Wecome tallpaul to FTE he's a friend of mine.
Old Nov 6, 2007 | 04:49 PM
Rangerman Stan's Avatar
Rangerman Stan
Welcome tallpaul14. We hope you like it here.
1996pwrstrk, all the 2.9s that I've had or seen have been hydraulic lifters. But some are noisy. And yeah, that's usually the best way to know for sure what's there. Getting under the truck and looking and checking numbers. Sorry! Hopefully all the tags are still there and are readable.
Old Nov 6, 2007 | 05:22 PM
rebocardo's Avatar
rebocardo
Cracks along the underbody floor seams (which is sort of normal). A compression check would be the best thing. Leaking gas tank.
Old Nov 7, 2007 | 10:14 AM
351c's Avatar
351c
My sister bought a '90 bII brand new "thought it was a 4x4 but it was a 2wd" hehe, she put 100,000 miles on it and then sold it to me. It now has 186,000 on it and the rearend, front end,motor, trans have never been opened up, I did a timingchain at 180,000 but it did not need it as it has a hydraulically adjustable tensioner. The lifters would make noise when first started then quiet down after oil got to them. 20/50 Mobil.1 stopped all lifter noise- all that has been done to it is basic maintainance. I wouln't sell it for anything..... actually im not stupid but it would take like 5 grand-
Old Nov 7, 2007 | 03:29 PM
tallpaul14's Avatar
tallpaul14
Thanks yall, I might get it this saterday if it is still for sale. seems like a good truck
Old Nov 8, 2007 | 11:44 AM
1996pwrstrk
Did you sell that white thing ? When you get your bronco II we'll get you signed in the Arkansas chapter. Congrats and Happy Birthday.
Old Nov 13, 2007 | 06:19 PM
McQue's Avatar
McQue
Check the body mounts...especially at the rear end, and the ones on each side just about middle of the body...I just repaired/refabricated the last 5 inches of the rear floor pan, cross beam that sits on the frame above the body mounts, and the body mount frame rail area as it was completely rusted out on my 90 Bronco II
Old Nov 15, 2007 | 06:15 PM
tallpaul14's Avatar
tallpaul14
THANKS GUYS, i GOT IT FOR MY B-DAY, HOPE IT TURNS OUT TO BE NICE, I'M FIXIN TO JOIN THE ARKANSAS CHAPTER.
neuge
Bronco II
13
Apr 25, 2014 02:33 PM
rachwatt
1978 - 1996 Big Bronco
Aug 4, 2010 10:45 PM
TurboJNR
Bronco II
Aug 10, 2003 07:28 AM
rbluhm
Bronco II
Dec 11, 2001 07:24 AM
Matthew Kindler
Bronco II
Feb 4, 2000 06:42 PM
