300 Help!
Old Sep 26, 2002 | 10:08 PM
65inline6's Avatar
65inline6
Post 300 Help!
Does anybody know what years the HD 300 was put in, and what truck? Also can you take 300 internals and put them in a 240 block without messing anything up?
Old Sep 26, 2002 | 10:30 PM
tetraruby's Avatar
tetraruby
300 Help!
Good luck finding a HD. There is not much for data on how to disciminate which trucks have them and not. I just picked up an engine from the junkyard (valve cover of a 300 HD). Well, I got the head off and measured the stroke and it ended up being a 240...in a 1 ton flat bed. The crank casting number also verified this. Going from a 300 to a 240..rods, crank, and pistons are out. You could use the 300 head on a 240 but compression will be really low. Cam and timing gears will interchange.
Old Sep 26, 2002 | 11:54 PM
WoodworkerJon's Avatar
WoodworkerJon
300 Help!
