bouncing/shutter at 40 mph
Old Nov 1, 2007 | 09:40 PM
sideshow's Avatar
sideshow
Question bouncing/shutter at 40 mph
sorry for the confusing title. recently had a new ford tranny installed,
(couldn't hold out for BTS) and now i have a unusual bouncing feeling right around 40 mph. isn't this approximately when the TC locks? if i'm on a relatively flat stretch of road, and barely into the throttle (almost coasting, but not quite) it feels almost like my truck bounces.
from what i had read, and the dealer told me, the new "heavy duty design" ford tranny was supposed to be comparable to aftermarket ones.......blah, blah blah. it supposedly had a heavier duty converter. could that be it. i mean aside from the occassional bouncing feeling, it drives/shifts great.
any thoughts. it has a 75k mile warranty, so not worried there, but wondered if it may be something else.
Old Nov 1, 2007 | 11:26 PM
twags6's Avatar
twags6
Mine does the same thing. It seems to the right speed where everything is vibrating just right and makes the truck bounce. Some are worse then others. You could try balancing the tires....it might help a little.
Old Nov 2, 2007 | 07:44 AM
fbilly420's Avatar
fbilly420
check your drive line center support bearing if the rubber part has play most likly that is your problem. They all have a little play but shouldn't be very much.
hope this helps
Billy
Thom12
6.7L Power Stroke Diesel
847
Sep 20, 2025 01:12 PM
wildstang
Vermont Chapter
Jul 14, 2013 04:21 PM
slfd1717
1983 - 2012 Ranger & B-Series
Apr 7, 2013 08:02 PM
stopp429
Jan 23, 2013 07:19 AM
Biggziff
Dec 18, 2007 08:55 PM
