Hey folk, here is one that has been driving me crazy the past few days. It has been happening just evey so often. I get these 5 beep five times then stops and sometimes it keeps going. When it first happened I thought it was the seatbelt alert. Checked them and very thing was fine.
Does anyone know what they mean. Can I disable the beeper.
96_4wdr I pulled the dash apart and found out that there was no bulb so I put one in. Now the beeping stoped but the Light is flashing. A friend said it may have been deployed at one time. And I think I have a voltage problem. Lost a belt and had to drive the van a ways with out one. Now after putting the belt back on the alt light stays on. Was read on the site that low voltage to the airbag may cause the light to flash. Could my Voltage regulator or alt be causing this problem?
Now that I had a chance to talk to a few owner I was told to take the #10 15amp fuse out and now for some reason I get code 12 not sure what this one is. I also thought that with the fuse pulled the light for the airbag would be diabled. I guess not.
