d50? d60? d44? im lost
Old Feb 24, 2006 | 12:26 PM
Never_a_Chevy's Avatar
Never_a_Chevy
Cool d50? d60? d44? im lost
i have a 91 f250 4x4 and im replacing the front rotors, bearings and brakes. im not sure which front axle i have. there is a big 50 cast into the front carrier does that mean i have a d50? it has 8 lugs and a large hub lock and that alone i think eliminates it being a d44 right ? i replaced the locking hubs before but i forgot which axle i got them for .
The reason im questioning this is because i just got all the parts for the d50 axle and the inner bearing will not go on. the rotors are right or seem to be but the inner bearings will not slide back onto the spindle without bashing them on with a BFH. i double checked the part number for the inner bearings and it is the correct one for a d50. and the inner seal fit into the hub perfect which also is for a d50 axle. i figured there was a bur or something on the spindle so i hit it quick with some fine emery cloth but still no go. any suggestions or comments would be greatly appreciated.
thanks in advance.
Old Feb 24, 2006 | 12:38 PM
andym's Avatar
andym
You either have a Dana 44 HD or a Dana 50. Both were available. If you have a supercab, it's a Dana 50. That was standard. You also have a 50 if the truck came with a snowfighter package, which you probably wouldn't know unless you had bought the truck new.
If it's got a "50" cast into it, it sure sounds like a Dana 50 to me. Can you take the inner bearing out and slide it onto the spindle? Is it just too small? Where did you get the bearings from? If you bought cheap bearings at autozone or Kragen, I wouldn't be surprised if they didn't fit even if they were the correct part.
Another way to tell is if the hub fills the entire hole in the rim, it's a Dana 50.
Old Feb 24, 2006 | 01:02 PM
Never_a_Chevy
i actually bought the inners from 2 different stores and neither will fit on the axle and both were for the d50 axle. yes the hub fills the entire center of the rim. i have only tried them on the driver side but i am gonna go back out now and pull the passenger side ant try them on there and see what happens.
Old Feb 24, 2006 | 04:10 PM
DaveBowman's Avatar
DaveBowman
Its a Dana 50.
Old Feb 24, 2006 | 10:51 PM
Never_a_Chevy
yeah it is a d50. i finally got it to go on with a little finess and some wd 40. just had a pretty good bur on it i guess. thanks for the help.
Old Feb 26, 2006 | 12:21 AM
F350JOHN's Avatar
F350JOHN
Its a Dana 50 TTB if its an 8 lug F-250.
Old Feb 26, 2006 | 12:35 AM
termyt00's Avatar
termyt00
remember there are 2 Dana 50's! One is a 4000lb and the other is a 4800lb, you can look at the hubs and tell; the latter (larger) has tapered hubs, the other has straight hubs like the F150, you'll find this out when you go to replace the Ball joints, the person at the Advance Auto/ Autozone will likely give you the wrong ball joints if you have the larger hubs .
Kirbys73F100
May 23, 2013 01:06 PM
2500ak
May 8, 2013 03:17 PM
maxride
Oct 15, 2011 02:17 PM
MThrasher16
Jan 24, 2011 04:09 PM
