New boots
Old Oct 31, 2007 | 09:37 PM
greedy737's Avatar
greedy737
Red face New boots
I want to change all my IC tube boots. Can I buy a long piece of hose and cut my own, or do you have to buy them by the piece? Where can I get them NAPA ?? What size ? Are they all the same size ? truck is 2001 F250. Done the CCV mod. What to clean up the oily mess.
Old Oct 31, 2007 | 09:49 PM
dadsgreenpsd's Avatar
dadsgreenpsd
You can go to a hydraulic supply house, and get low pressure hydraulic return hose. I bought the kit, and that is what the boots are made of. The kit did come with new clamps, however. They have a spring which keeps them from being too tightly clamped, and damaging the tubing by collapsing it.
Old Oct 31, 2007 | 10:05 PM
greedy737's Avatar
greedy737
Where do you get a kit from and how much $$$$$ ??
Old Oct 31, 2007 | 10:07 PM
santacruzf250's Avatar
santacruzf250
I cant remember exactly which vender but one of the sites sponsors sells a complete kit, blue in color. Someone should come along shortly and chime in.
Old Nov 1, 2007 | 12:52 AM
bigjake0524's Avatar
bigjake0524
I bought mine from Dieselsite.com came with all new clamps and boots.
Old Nov 1, 2007 | 03:02 AM
ron's power stroke's Avatar
ron's power stroke
can not go wrong with these..
http://www.dieselsite.com/index.asp?...ROD&ProdID=133
these are ok if you like the stock look..
http://www.puredieselpower.com/catal...kit-p-496.html
Old Nov 1, 2007 | 05:43 AM
greedy737's Avatar
greedy737
So it's better to buy the kit, than to cut your own? Should I get new clamps, or can I use the old ones?
Old Nov 1, 2007 | 05:50 AM
ron's power stroke
you can cut your own for the 4 boots on the spider end of it with marine exhaust hose..but the IC end is 2 different sizes..it steps up from the IC pipe to the IC..as far as clamps..it depends how bad of shape yours are in..
Old Nov 1, 2007 | 05:55 AM
greedy737's Avatar
greedy737
Thanks for the info.... I think I will order them..
Old Nov 1, 2007 | 06:13 AM
ron's power stroke
if you plan on a bigger turbo later on..id get the boots from diesel site..other then that the pure diesel is just like the stock boots..
Old Nov 1, 2007 | 09:17 AM
rbaker6336's Avatar
rbaker6336
I got mine from dieselsite and are much better than stock
Old Nov 1, 2007 | 09:30 AM
ron's power stroke
i have Bob's boots as well..very heavy duty boots..there made to hold 50 psi with ease...
